Well, they haven't rusted and disintegrated in the last 50 years...
What year is the car? A.I.R. (smog) pumps date back to the mid-'60s on certain engines and/or delivery locations. That your manifold has the holes/tubes for the pump seems to indicate it originally had the system. (Do both manifolds have the holes?) Those cars that did not have the A.I.R. system installed did not have manifolds with the holes/tubes.
Take the tubes out and keep your uncracked manifolds. If you don't have the AIR manifold you can use plugs. The tubes are a loose part inserted from the outside before the smog pipe manifold is installed. I removed them on my LT-1 because of the flow restriction even though I have the full AIR system present. The tubes were there to dump the incoming fresh air as close as possible to the hot exhaust port to maximize the effectiveness of the system. Since most of us don't really care if we pollute a tiny bit more with our old cars, the tubes don't need to be there. I actually only found 7 tubes present when I opened mine up. Someone in the past had already taken one out.
You don't say what year engine you have, but if your exhaust manifolds have plugs it originally had smog tubes. Removing the plugs can be very difficult, but to remove those tubes intact you need to remove the plugs. If you think they are a problem and can't/dont want to remove the plugs, cut them off best you can.
I believe they are made of stainless. They just sit in there with a lip holding them in. So they are loose and floppy and spin.
I lifted up on them as high as possible and cut them off with a dremel. Then I turned them sideways and used a punch to tap them flat. Simple to pry them out.
This car may have come with an A I R pump originally. From what I can decipher, it was removed decades ago. I don't believe the manifold was ever removed. That is why those little pipes were still in there. Those allen heads are never coming out with a wrench. Only a drill and re-tapping will put them back to original. I can live with them the way they are.
I realize this is just academic stuff that a lot of folks don't care about, but here goes anyway. The following is from Jim Shea back in 2006:
Originally Posted by Jim Shea
Here is what I have for A.I.R. useage in the Vettes. I may have obtained this information from Saginaw Steering Gear who manufactured the original A.I.R. pumps.
1966 California delivered Vettes used the A.I.R. (RPO K-19) system except for L-72.
1967 All California delivered Vettes used the A.I.R. (RPO K-19) system.
1968 & 1969 All Corvettes used the A.I.R. system regardless of engine or transmission.
1970 Chevrolet went to the CCS (Controlled Combustion System) for emissions control on most Vettes except the LT-1s which used A.I.R.
1971 Corvettes continued with CCS (except LT-1s and LS-6s which used A.I.R.
1972 The A.I.R. system returned for most Vettes except L48s with the "CKW" and "CKX" codes.
1973-1975 All Vettes used A.I.R. except for the 1974 L48 with automatic and Federal emissions which used CSS.
1976 All Vettes returned to CCS except California certified cars which used A.I.R.
1977 All Vettes used CCS except California and "High Altitude" delivered cars which used A.I.R.
(Not sure on the 1976 and 1977 Vettes with L82s, they might have used A.I.R.)
1978 & 1979 All Corvettes used CCS except California cars, "high altitude" and all L82s which used A.I.R. L82s were not available in California or "high altitude" areas during these years.
