4 speed shifter mount bracket Q
Old Dec 22, 2023 | 07:40 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
Default 4 speed shifter mount bracket Q
Can anyone identify the year of this shifter bracket? I have found at least three variations of the same bracket. Some have a welded bracket/plate between the two vertical holes, others don't. Another looks like this one but has
a extra relief on the horizontal section. Etc.
Old Dec 22, 2023 | 08:04 PM
Rowdy Rat's Avatar
Rowdy Rat
As you noted, there are at least three different variations. This one is the 1971-1972 version, but it appears to be missing the weld nut at the top. There is a nearly identical bracket with a small hole in the horizontal section… That one is for 1969 -1970. The one with the support bar running between the two mounting holes (as well as a smaller “window”) is for 1973 -1979. I would imagine that 1968 is similar to the 1969 - 1970 version, but I can’t be certain. I have no idea what the 1980 mount looks like.
Regards,
Stan Falenski
Old Dec 22, 2023 | 08:19 PM
Tewski's Avatar
Tewski
Regards,
Stan Falenski
Wow, great info, thank you!
To 4 speed shifter mount bracket Q
