Headlight connection
Old Jan 15, 2024 | 04:22 PM
JC Pilcher's Avatar
JC Pilcher
Default Headlight connection
In the middle of getting things prepped for the body shop and noticed the headlight connections are not the best and two are broken. Is there a source for new connectors that have the fiber optic connection as well? Trying to get away from buying a whole new harness.
Old Jan 15, 2024 | 06:00 PM
bmotojoe's Avatar
bmotojoe
Mouser Electronics
3 Wire Connector Housing Link: https://www.mouser.com/ProductDetail...bmX4hbYQ%3D%3D
2 Wire Connector Housing Link: https://www.mouser.com/ProductDetail...aICM49MQ%3D%3D
If you need the crimp terminals they are not the standard series 56 (1/4") terminal, they are series 59 (5/16") terminals.
There are 2 different terminals used on those housings, a double wire and a single wire.
Double wire terminal is GM #2973215
Single wire terminal is GM #2973216.
Minimum order for the terminals through Mouser is 20ea.
Here are the connector housings if you do not do links...
One of the double wire crimp terminals...
Old Jan 15, 2024 | 06:16 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
If you want assembled, I think Lectric Limited sells just the pigtails.
Old Jan 15, 2024 | 10:51 PM
Richard454's Avatar
Richard454
Here's some pigtails- handles fiberoptics $2.54/ea no minimum purchase
https://www.delcity.net/store/Headli...98105.h_818652
To Headlight connection
