Seat belt web replacement
Old Feb 1, 2024 | 08:44 PM
OMF's Avatar
OMF
Default Seat belt web replacement
Has anyone on here used SAFETYRESTORE to re-web their belts? If so would you use them again, and how about the color match?
I'm just about to send my stuff off for a refurbish and thought I'd ask here first.
https://www.safetyrestore.com/seat-b...or-elegant_red
Old Feb 1, 2024 | 09:28 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Are you looking for an accurate restoration like the belts when they were new? Charlie Santorelli at Seat Belt Sity is highly recommended for originality-focused refurbs.
Old Feb 2, 2024 | 03:16 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I've read on here many times guys have used Snakeoil. But I just bought new belts.
Old Feb 2, 2024 | 08:32 AM
speedreed8's Avatar
speedreed8
Snakeoyl. Texas.
Old Feb 2, 2024 | 05:00 PM
ctmccloskey's Avatar
ctmccloskey
They appear to be a reputable company at Safety Restore. I am very glad somebody is doing that kind of repairs. The NTSB (National Transportation Safety Board) here in the U.S. suggests that the entire seat belt assembly in passenger cars be replaced after 10-15 years. I am not so sure you need to replace the metal pieces as the replacements might not be as good as the original metal parts.
I had to replace the entire set of seat belts out of my Cessna 172 and new seat belts properly made to pass the FAA requirements since they were over 15 years old. In the airplane world the belt should protect you from a 4 G accident/crash and have manufacturing Dates on them. I am not sure the rate for automobiles accidents. A 4 G accident would be the end of many Corvettes and the occupants might not far well with older seat belts not retraining the passengers.
Under the fiberglass floor is a fender washer and a nut holding one end of the seat belt to my car and I now know that some Bubba removed the plate that spreads out the force when the seat belts gets pulled. If I have an accident with my C3 it is likely that the bolts would rip through the floor allowing me to fly or get impaled on the steering wheel. To make matters worse is that my car came with only lap belts. I want to keep my Corvette safe. I spent a lot on brakes and even more to go faster so what is a couple hundred for new seat belts to keep the passenger safe.
Old Feb 2, 2024 | 05:33 PM
OMF's Avatar
OMF
Thanks for your insight there guys, I'll look into your recommendations.
Old Feb 2, 2024 | 05:41 PM
OMF's Avatar
OMF
I had a '52 Piper Pacer and replaced the belts (upgraded to shoulder harnesses) in it around 2018......the belts were dated 1954 and 1956.....I don't think they would have been much use in an accident.
For my car the metal hardware is all in really good shape, but the belt webbing is sun faded and has the odd nick in the web. I just redid the interior as well and with tat done the belts just look really tired...time for a refresh!
Get that floor mount fixed up, you likely won't get a second chance!
Old Feb 3, 2024 | 12:05 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Originally Posted by speedreed8
Snakeoyl. Texas.
They did mine, including T-Top straps. All metal was re-chromed and the retractors restored. Paid $828 in 2017. Could not be happier.
Old Feb 3, 2024 | 11:05 PM
speedreed8's Avatar
speedreed8
They recently replaced my retractor springs on both sides. $120. Work like new oem now.
it helps they are near where I live.
snakeoyl 👍
To Seat belt web replacement
