Fiber Optic Install Advice?
Old Feb 23, 2024 | 12:54 PM
K-Dog's Avatar
K-Dog
Default Fiber Optic Install Advice?
I just finished installing a new set of FO in the rear, now about to tackle the front.
Anything I should know, do, not do, etc.??
My plan is to pull out the front harness, take all the old tape off, remove the FO, place the new FO, tape it up, and lay it back in place.
After doing the rear wiring, it seems like a good idea to leave the "tails" taped up in the same configuration and length, before taping up the entire harness.
Old Feb 23, 2024 | 02:19 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
just make sure the ends have enough loop that they dont have to have a sharp bend to go into the receptacle...
Old Feb 24, 2024 | 01:46 AM
JETS C3-C4's Avatar
JETS C3-C4
Also make sure when routing under the dash on the drivers side make sure to stay away from the courtesy light. It can get hot enough to melt thru the harness. Don't ask me how I know this.
Old Feb 24, 2024 | 07:23 AM
sw69vette's Avatar
sw69vette
How old is your wire front wire harness ? If its original I would replace it . You can get the wire harness complete with fiber optics .You don`t want to do that job again .
To Fiber Optic Install Advice?
