1968 correct key blanks
Old Feb 26, 2024 | 11:33 AM
krazeehorse's Avatar
krazeehorse
Default 1968 correct key blanks
What keys were original to the 1968? The octagonal and rounded or the larger rectangle and rounded? Thanks, Kevin
Old Feb 26, 2024 | 12:02 PM
krazeehorse
According to ebay the larger ones are correct. The octagon was last used in 65 or 66.
Old Feb 26, 2024 | 12:10 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
The octagon and round smaller ones are OEM for a 1968. 1969 and up used the larger square and round.
Old Feb 26, 2024 | 12:37 PM
krazeehorse
Thanks!
Old Feb 26, 2024 | 03:52 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Dash application VS Steering column.
Old Dec 16, 2024 | 10:19 AM
73bbc's Avatar
73bbc
Sorry, wrong thread
Old Dec 16, 2024 | 11:14 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
More than you asked for...
The octagon and pear keys had two iterations: #1 through '66 and #2 for '67 & '68. 1967 keys introduced key blades with different grooving for more key combinations (i.e., security) from year to year. The '67 keys carried A-code on the ignition and B-code on the locks - this A/B code was repeated in '71, '75, '79, '84/85. 1968s had C/D codes on the blades which repeated in '72, '76, and '80; '69s introduced the rectangular and oval headed keys with E/H coded blades and '70s had J/K blades, both following the same 4-year skip pattern. (I assume F/G/capital-i were not used because of potential confusion with E, C, and H.)
The '67 A/B and '68 C/D are kinda odd ***** because they had the old look but the new key coding system. Because the letter pairs repeated, using the rectangular and oval heads will work just fine for '67 and '68.
To 1968 correct key blanks
