Storing jack inside spare tire
Old Feb 29, 2024 | 01:28 PM
pete315's Avatar
pete315
Default Storing jack inside spare tire
Anyone store their jack inside the spare tire rim like the C4’s do? Just curious.
Old Feb 29, 2024 | 02:03 PM
TX427C3's Avatar
TX427C3
Active Streak: 90 Days
St. Jude Donor '06-'09,'22,'25
Just curious why you would want to, when you have a perfectly good place to stow the jack?
Old Feb 29, 2024 | 02:11 PM
kanvasman's Avatar
kanvasman
If you wan tto free up the space in the storage compartment, for an amp for example, no reason you couldn't do that. THe only issue might be if you need the jack handle to lower the spare tire tub.
Old Feb 29, 2024 | 02:45 PM
pete315's Avatar
pete315
I thought to prevent rattling noise. I have to figure out proper way to mount. I do see a spring lying in there. I’ll have to find a picture of proper mounting.
Old Feb 29, 2024 | 03:30 PM
kanvasman's Avatar
kanvasman
The spring works fine to keep it from moving around. Find a picture of the correct set up. One of the few things the engineers did right.
Old Feb 29, 2024 | 03:48 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
My spare tire rim is full of stuff, fan belts, bottle jack, spare electric fuel pump, brake fluid, trans fluid.
I take my car on long trips like the Hot Rod Power Tour so I have to be prepared.
Old Feb 29, 2024 | 03:54 PM
ignatz's Avatar
ignatz
Hypothetically, your car is lowered, and you have a flat in the rear which prevents you from lowering the tub enough to get the jack out. That's why!
Old Feb 29, 2024 | 04:19 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Your jack storage sticker clearly shows the correct way to stow your jack. It should be on the inside of the compartment door.
your's is clearly missing. Perhaps get a new jack storage instruction sticker. Most Corvette vendors sell reproductions.
Or just look on a vendors website of that sticker.
Old Feb 29, 2024 | 04:51 PM
riverracer au's Avatar
riverracer au
When I do long trips or interstate runs, I carry my tools and a few small spares in my spare tyre rim. In my jack storage tub, there is a couple of aluminium pry bars to get my P02 wheel covers off, the jack lever and the jack held by the spring. Surrounding all of that, there's rags for hand cleaning and a large towel for laying on if needed to work under the car. The towel also helps to stop every thing from bouncing around and making noise. All that is under the storage tub, which also I fill with the odd spare part.
Old Feb 29, 2024 | 05:01 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old Feb 29, 2024 | 05:50 PM
1860army's Avatar
1860army
The jack is where it belongs...I have an amp above it in the tray. Spare tire has jumper cables, fan belts, rags, gloves, zip ties, duct tape, flat fix, tire plug kit, a better lug wrench, couple beers, ... essentials...
60
Old Feb 29, 2024 | 07:24 PM
BKarol's Avatar
BKarol
jump to 3.20
Old Feb 29, 2024 | 09:44 PM
pete315's Avatar
pete315
I actually just watch this video. Thanks.
Old Feb 29, 2024 | 10:56 PM
Bikespace's Avatar
Bikespace
Why stick it there? My jack, spare tire, and spare gas can, fit in my wallet. There's room in the glove box for a spare HEI module and a few tools, though.
Old Mar 1, 2024 | 05:13 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
I don't have the original jack for our '78, it didn't come with it when we bought it in 1990 and when I looked at buying a correct item recently the price was horrific! I have an aftermarket scissor jack that works well and luckily fits into the space in the rear and is held down by the spring. That same compartment holds various spares, WD40 spray, some tools, cloths etc.
I carry spare belts in the spare tyre, but I'm a little concerned about the weight - I changed out the original spare tyre for a new item that weighs considerably more then the original, so not sure about loading up the spare wheel tub too much. Looking at what some of you guys carry I'm thinking this concern is unjustified!
Old Mar 1, 2024 | 06:06 AM
4-vettes's Avatar
4-vettes
In my 77 spare tire tub I have a 255/60-15 tire on a factory steel rim. And my really good, really long SnapOn jumper cables.
Old Mar 1, 2024 | 09:45 AM
pete315's Avatar
pete315
Anyone with a 60’s or 70’s Mopar usually had 3 ballast resistors in the glovebox😁
To Storing jack inside spare tire
Old Mar 1, 2024 | 10:25 AM
Midnightsun1's Avatar
Midnightsun1
here’s the jack in my 81 c3. It has never been removed not once in 43yrs.
Old Mar 1, 2024 | 12:22 PM
pete315's Avatar
pete315
Great picture. Thanks.
Old Mar 2, 2024 | 06:15 AM
Stephen Irons
Not even to clean it? It looks like new!👍
