Torque specs for LT-1 bottom end
I found the spec for the rear main cap and oil pump bolt, but don't see anything in the service manual for the 3 nuts that hold the windage tray.
What would the correct torque be for those nuts? Should i re-torque the bolts for the main caps those were attached to? Is the oil pump bolt torque different from the manual due to the windage tray?
Thanks,
Oil pump I always use a stud and go 35-40ft/lbs......the stock GM spec on this for the bolt is a scary one.....65ft/lbs. distorts the cap and can pull a chunk out of it in some instances.....
Just tighten the windage tray nuts snug with lock washers......or serrated flange nuts. No you do not have to re-torque the cap bolt.
Jebby
