What's going on here ....... ? ? ? ? ?
Old Mar 6, 2024 | 03:07 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Default What's going on here ....... ? ? ? ? ?
What's going on here ....... ? ? ? ? ? Bounce, Bounce, Bounce .
Battery Gauge, Bounce @ Idol, Bounce @ Rev. Bounce @ Cruise - Lose wire / ground ? Bad gauge ? - Thoughts ?
Click on video below: Thanks !
File Type: mov
Old Mar 6, 2024 | 05:15 PM
MelWff's Avatar
MelWff
Did you check all connections on the alternator to start with, the large red wire, and the connector with the two smaller wires?
Old Mar 6, 2024 | 06:36 PM
427SIXPACK's Avatar
427SIXPACK
No, but I will now, wasn't sure how or where to start. 2 peeps, one to wiggle wires & one to watch i guess ?
Does the video play ?
Old Mar 6, 2024 | 06:52 PM
Duke94's Avatar
Duke94
Yes, it plays. Lose wire someplace.
Old Mar 6, 2024 | 07:58 PM
BKarol's Avatar
BKarol
I had a problem with the black wire that was inside the pigtail connector on the alternator,( two wire) . Black wire was broken inside the connector..
Old Mar 6, 2024 | 11:36 PM
427SIXPACK's Avatar
427SIXPACK
Will check that as well, thanks for the suggestion.
Old Mar 7, 2024 | 12:20 AM
Hopper12's Avatar
Hopper12
I had the very same problem on our '68 - exactly like that. I checked out all sorts of stuff, and it ended up being the gauge itself. I found one in the FS section, replaced it, and it's worked great ever since. Hope you figure it out. Best, Paul
Old Mar 7, 2024 | 12:37 AM
427SIXPACK's Avatar
427SIXPACK
Hoping that's NOT it ...............it's such a pita taking that center unit out, apart & back in. That's why the top sections of these on most cars are broken. I will check out the wires to the alt tomorrow after work.
Old Mar 9, 2024 | 12:35 PM
Crimson Thunder's Avatar
Crimson Thunder
That is why I installed a Volt meter in place of the ammeter.
Old Mar 9, 2024 | 12:50 PM
427SIXPACK's Avatar
427SIXPACK
Curious what the difference really is ? Also if it's a bad gauge or a lose wire it wouldn't matter the result would be that same no ? What I mean is if a voltmeter was installed instead & it was a bad gauge or a lose wire there would still be an issue.
Old Mar 9, 2024 | 01:46 PM
Bikespace's Avatar
Bikespace
That looks too periodic to be a loose wire.
Do you have a multimeter and know how to use it? If it were my car, I'd take a bunch of voltage measurements (AC and DC), then try a different alternator.
Old Mar 9, 2024 | 02:03 PM
427SIXPACK's Avatar
427SIXPACK
Yup, I know how to use it......................BUT, I loaned it out & of course never got it back. No battery issues ever, charges fine, always starts, with no strain or dimming. BTW - it's a LAME OEM 42 amp alt.
Old Mar 9, 2024 | 06:51 PM
jersey68l36's Avatar
jersey68l36
Same thing happened to my '68. It wind up smoking the connection that goes to the ign switch.
Recommend not driving it until the bounce is resolved.
Old Mar 9, 2024 | 06:55 PM
Bikespace's Avatar
Bikespace
It's probably worth picking up another one for $20-. Or a nice Fluke for $100+.
Old Mar 9, 2024 | 07:28 PM
ZIOGEO's Avatar
ZIOGEO
Alternator is internal or external regulated ?
Im gonna put my money on one of the diodes failed short or the gauge failed.
Any junk yards still on Long Island? They were disappearing fast about the time I moved out
Old Mar 9, 2024 | 07:49 PM
Hopper12's Avatar
Hopper12
right you are, and mine is broken - I'm pretty sure it was before I had to take it apart. I didn't think it was all that bad, really. I had to take it apart again a year later to replace the oil pressure line - so now I'm an expert! Best of luck with it, Paul
Old Mar 9, 2024 | 08:07 PM
MelWff's Avatar
MelWff
His profile says 68, so if original, external regulator.
To What's going on here ....... ? ? ? ? ?
Old Mar 9, 2024 | 08:20 PM
427SIXPACK's Avatar
427SIXPACK
on the drivers side fender well.
Old Mar 9, 2024 | 08:22 PM
427SIXPACK's Avatar
427SIXPACK
There were a ton, but property values closed most of them.
Old Mar 9, 2024 | 11:09 PM
ZIOGEO's Avatar
ZIOGEO
Is the voltage regulator a newer electronic kind or an original mechanical type?
