Spark plug wires- where date code stamped?
Old Mar 12, 2024 | 12:47 PM
pete315's Avatar
pete315
Default Spark plug wires- where date code stamped?
I’m just starting to do plugs, wires, cap and rotor on my 81. I think car has original wires. They are gray with black boots. Wires read Delphi Packard 8 mm Made in USA every 2 inches. I just don’t see a date code. Any idea this date code would be? It’s a 57k miles car and the wires appear to be routed the way in came from factory. Wires for # 1,2,5 and 6 go between engine and motor mounts.
Old Mar 12, 2024 | 01:13 PM
pete315's Avatar
pete315
I have a miss in cylinder #8. I took the plug out and it’s not fouled up. Little wet with gas though. I just did a compression test in that cylinder and got a reading of 130. That’s why I’m leaning towards a bad wire.
Old Mar 12, 2024 | 05:02 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Perhaps you do have a poor plug wire. Would only take a minute or 2 to check it with an ohm meter.
I have never seen a date code on a plug wire.
And I would be running that compression test on at least a few more cylinders for comparison. Guages can vary. But 130 sounds VERY low.
I don't know alot about the 81 engine. But thinking readings around 170-180 would sound alot better.
Old Mar 12, 2024 | 08:53 PM
62corvette's Avatar
62corvette
Plug wires from at least as early as ‘57 were dated, at least through the mid-70’s.
Old Mar 13, 2024 | 07:41 AM
4-vettes's Avatar
4-vettes
As I said, I've never seen a date on one. Doesn't mean it wasn't there. Perhaps I never knew to look for it.
If your certain they were dated. Perhaps you could clue us all in as to where to look for it.
Old Mar 13, 2024 | 08:50 AM
bmotojoe's Avatar
bmotojoe
Here is one of my original 3rd quarter dated plug wire off my 77.
Can't remember if it was 2 or 3 as both are the same length...
Old Mar 13, 2024 | 10:08 PM
pete315's Avatar
pete315
I did a compression test on all the cylinders except # 2 and 4 because I had to drop the starter to change the wires. All other cylinders were right there at 130 give or take only 1 psi. After wires change, that miss is gone. I removed wire 8 while car was running and car rpm’s came down, unlike before. No more slight stumble at idle. I would say these were definitely the original wires. Have to say, changing wires was not as bad as the hype. Maybe I’ll change them again in 2064.
To Spark plug wires- where date code stamped?
