Weird Noise. Need advice/help diagnosing!
Old Mar 15, 2024 | 05:36 PM
ahugo75's Avatar
ahugo75
4th Gear
Default Weird Noise. Need advice/help diagnosing!
Hey guys, I have a 1978 Corvette that has been making a high pitched repetitive squeaking noise when driving at higher speeds. It only seems to happen when the car is warmed up, and driving at speeds above 45mph. The faster I go the louder it gets.
While sitting in the driver's seat is sounds like it coming from directly in front of me, and it is louder from within the vehicle than if I listen to the noise outside. I have played with gears and rpm, and it seems unrelated. Additionally, applying the brakes doesn't seem to affect the sound either. The only thing that affects the sound is speed.
I've attached a sound clip of the sound recorded from the inside of the car at about 55mph.
Any ideas? A bad bearing doesn't sound this high pitched does it? It's also weird to me that it is only occurring on long duration trips. I can go 60mph 5 minutes into the drive and it doesn't make a sound.
File Type: mp3
Old Mar 15, 2024 | 05:39 PM
sunflower 1972's Avatar
sunflower 1972
I'm thinking alternator. Disconnect belt and run it.
Old Mar 15, 2024 | 07:05 PM
ahugo75's Avatar
ahugo75
4th Gear
Thanks, I'll give it a try!
Old Mar 15, 2024 | 07:16 PM
killain's Avatar
killain
Oldtimer
I think sunflower is right, and I'd see if one of the brackets might have a crack or broken mounts.
Old Mar 15, 2024 | 08:48 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
first thought water pump
wiggle fan
Old Mar 15, 2024 | 08:49 PM
Redvette2's Avatar
Redvette2
If it doesn't change pitch with changes in rpm's it would seem not to be engine/alternator related. Have you tried changing the speed of or disconnecting the ventilation fan?
Old Mar 15, 2024 | 09:21 PM
Golfobsessed's Avatar
Golfobsessed
Had the same going on... purchased an engine stethoscope from Amazon and heard it in my water pump right away, was a great cheap purchase.
Old Mar 15, 2024 | 11:24 PM
Bikespace's Avatar
Bikespace
If it was engine related, it would be RPM dependent.
Does the frequency change if you change speed? Does it stay the same if you pop the car out of gear and coast? If so, I'd suspect a wheel bearing, or something scraping on a wheel/rotor.
Old Mar 16, 2024 | 05:36 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'd be checking wheel bearings, when is the last time you repacked them? What type of grease did you use?
Old Mar 16, 2024 | 07:29 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
Having listened it I'd be tempted to say that it might be something to do with the speedo cable? You say it sounds as though its right in front of you when you are driving. Could be the cable, or maybe the speedo head itself, it just needs to "warm up" a bit to squeak?
Old Mar 16, 2024 | 11:52 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
To reiterate, if you shift into neutral at speed, the sound stays the same? I think it's a rubbing squeak rather than a rotational bearing squeak (which should change with engine speed). Have you noticed any difference due to road smoothness?
I'd suggest it's an exhaust connection pipe squeak -- check the connections at the manifold and the frame's transmission crossover.
Old Mar 16, 2024 | 02:24 PM
ahugo75's Avatar
ahugo75
4th Gear
Yes, the sound remains the same when shifting into neutral at speed. I don't notice a road smoothness difference either. Super confusing to me. Ill check connections at manifold/transmission crossover.
The heat seems to be a big factor in the noise. As soon as I start to feel the hot air coming from floor/vents after driving for a while, the sound begins. Then that sound is completely dependent on the speed I'm going.... not the engine, gearing, brakes, or turning!
Old Mar 16, 2024 | 04:15 PM
beachmusic's Avatar
beachmusic
I,m unclear. Is the noise only while car is moving? If so, it sounds a lot like the speedo head to me. I had this happen once, but the speedo needle bounced around at the same time as the noise. Good luck.
Old Mar 17, 2024 | 04:46 AM
Stephen Irons
Agree. I'd said maybe the cable, but listening to the recording a few times (and comparing it to how our '78 sounds, it does sound like it could be the speedo head. The OP says that he hears it as soon as warm air is coming through the vents. If that warmth was enough to allow the cable to flex a little maybe that would squeak, or maybe warm the actual speedo head, with the same results.
If it was me I'd pop the speedo cable off the head and go for a drive before doing any major disassembly of components.
Old Mar 18, 2024 | 11:11 AM
ahugo75's Avatar
ahugo75
4th Gear
The speedometer was the issue; I disconnected the cable from the head, and the noise was eliminated. Thanks for all of the ideas guys! It's interesting that the cable would warm up and then start squeaking.
Now it's a question of how to fix this problem. The cable was working; just noisy... Should I pull it through the housing and grease it up? Then try to funnel it back through?
Old Mar 18, 2024 | 01:40 PM
Stephen Irons
Glad you got the noise isolated - I thought it sounded like the speedo when I listened to your recording.
When I changed the speedo cable on ours (to re-instate the cruise control) I released it from the speedo head and tied a piece of string to the end. I then pulled the cable out from the engine bay, making sure I had enough string left inside the car. I then swapped the old cable for the new on the end of the string and gently pulled teh cable back into the car. A little tricky, but it worked and it meant the new cable followed the same route back to the speedo head. Of course, you still have the fun job of fitting it at the gearbox.....😱
On balance, I think if you can, I might try pulling the inner and greasing it, and feeding it back in!😄
The only caveat to all the above that might be that as the noise stopped when you dis-connected the cable from the speedo head, does that not imply the head is the issue? Just a thought.....😳
Old Mar 18, 2024 | 01:49 PM
topl3ss1's Avatar
topl3ss1
2nd Gear
hello, i had a similar noise issue on my '89. mine turned out to be the smog pump AIR injection pipe coming off the cat. not sure if your car has the same smog setup.
To Weird Noise. Need advice/help diagnosing!
