Center bezel console break prevention
Old Mar 21, 2024 | 03:42 PM
c1nicole's Avatar
c1nicole
Default Center bezel console break prevention
Known fact these tend to break on the upper 1/3
very easily during installation/removal.
Thought I remember someone mentioning that you could add some kind of reinforcement to help prevent breakage.
Anyone remember this or could share what you did to prevent this from happening?
Getting ready to start installing vent ducts vintage air, hook everything up and test before buttoning down the console/dashes. Really looking forward to this enjoyable task. 🙄 “Sarcasm” alert!🚨
As the saying goes “An ounce of prevention”
Pictures even more helpful.
Old Mar 21, 2024 | 03:48 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
I have mentioned that in the past. If broken or as you said “preventative”, consider a small strip of stainless steel (thin) and adhere it to the side of the common break area ( side that is not seen). I would guess JB WELD may work to adhere the stainless. Even a wider piece would still be covered by the wiper bezel once installed. Just an idea.
Old Mar 21, 2024 | 04:18 PM
c1nicole's Avatar
c1nicole
I know someone had a great post on this but it was deep in a thread and now I cannot find it!
It was something like you are stating that
gave extra strength to that area. Want to be sure whatever I use will not impede correct fitment during installation.
Old Mar 21, 2024 | 09:19 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Here are 4 threads that deal with the problem...
https://www.corvetteforum.com/forums...el-repair.html
https://www.corvetteforum.com/forums...int-match.html
https://www.corvetteforum.com/forums/c3-general/4638506-69-center-dash-bezel-repair.html
https://www.corvetteforum.com/forums/c3-general/3963575-repairing-the-center-console-guage-bezel.html
Hope they help!
Paul
Old Mar 21, 2024 | 09:43 PM
c1nicole's Avatar
c1nicole
Fantastic. Thank you.
mine is not broken and hope to keep it that way. Will reinforce with the zinc plated steel!
Old Mar 23, 2024 | 07:35 PM
loup68's Avatar
loup68
Army
I suggest what I always do. Remove the right hand passenger side lower dash first. Lou.
Old Apr 1, 2024 | 11:37 PM
c1nicole's Avatar
c1nicole
everything currently put so….
Still have to modify lower passenger dash to accommodate the vintage air we had installed.
To Center bezel console break prevention
