Block numbers
Old Mar 24, 2024 | 07:24 AM
elpasorabo's Avatar
elpasorabo
Default Block numbers
So picked up a 1974 454 corvette the other day. After the engine washing I was surprised to see the motor plate with some unusual markings. I had heard back in the day when motor shops had decked an engine they sometimes restamped the blocks and also heard of some crazy block stamps but wanted to get some thoughts from some of you that had seen more of them than me. The block has the correct mold marking in the back the front stamp is suspect. Thoughts?
Old Mar 24, 2024 | 10:51 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The double Vin sequence isn't that concerning being off kilter & twice stamped – errors happened. The engine build stamp however looks like it's been ground out after the option code. If it has, then the VIN stamp is definitely not original. Can you take another pic of the pad straight down?
What is the casting date of the block? Should be on the rear flange, passenger side.
Does the VIN sequence match the VIN tag on the pillar post and the blue certification label on the driver door above the door latch? A pic of the door label would be good to post too.
Old Mar 24, 2024 | 11:08 AM
69L88's Avatar
69L88
The 3999289 casting number indicates it is a truck block, not installed in any Corvette.
Old Mar 24, 2024 | 11:22 AM
barkingrats
Actually it was... and not just trucks:
Old Mar 24, 2024 | 11:30 AM
elpasorabo's Avatar
elpasorabo
Default Numbers
that’s how I read the data sheets as well, that they used that block in both trucks and cars. I hand heard stories of double stamping. But I’m like you I worry about the missing information past the initial CW. It does look like it may have been ground.
Old Mar 24, 2024 | 12:25 PM
ed427vette's Avatar
ed427vette
The first partial vin number looks like it had a partial factory grind out of a stamp above it. Maybe it was vin stamped 3 times. The fonts look good. Somebody who really has experience with stamps would need to look at the pad much more closely and compare to stamps from the same time. I am not convinced it’s a restamp yet. The only thing I’m sure of is that it’s very hard to tell anything unless it’s very obvious. I’ve seen some amazing restamps and some original abominations. It’s really hard to pin down.
Old Mar 24, 2024 | 12:29 PM
Pboyd's Avatar
Pboyd
It looks like the St. Louis assembly plant messed up on their first attempt at the vin stamp. Show a better picture of the Tonawanda stamp to see if it looks OK.
Old Mar 24, 2024 | 01:37 PM
elpasorabo's Avatar
elpasorabo
Tonawanda Stamp?
Old Mar 24, 2024 | 02:21 PM
drwet's Avatar
drwet
That's a weird one. Tonawanda stamp is the one done at the engine assembly plant in Tonawanda. It will give the date and a two or three letter identifier indicating what engine it is. The VIN stamp was done on the assembly line as the car was being built. It looks to me like someone took a die grinder to the pad for some reason before the VIN stamp was done. Hard to tell. Get a better picture and post that.
Old Mar 24, 2024 | 03:27 PM
Bikespace's Avatar
Bikespace
Before you dive too deep, does that VIN match the car? How about the date codes? Does the car's birthday (encoded on the trim tag) match the VIN sequence?
CW-something is correct. Can you make out the third letter?
https://corvettec3.ca/engines.htm
Old Mar 24, 2024 | 09:23 PM
elpasorabo's Avatar
elpasorabo
I will try to get some better pics tomorrow and send out
Old Mar 24, 2024 | 10:54 PM
69L88's Avatar
69L88
Whoops
Old Mar 25, 2024 | 05:52 PM
elpasorabo's Avatar
elpasorabo
Default Matching numbers?
Here are a couple more photos of the numbers.
Old Mar 25, 2024 | 05:56 PM
elpasorabo's Avatar
elpasorabo
I added a couple pictures. Unfortunatley the trim tag is gone.
Old Mar 25, 2024 | 06:04 PM
Bikespace's Avatar
Bikespace
Thanks for the photos!
There were 4 options for CW* in a 1974 C3:
CWM 454 LS4 275 4-Speed
CWR 454 LS4 275 Turbo Hydra-Matic 400
CWS 454 LS4 275 Turbo Hydra-Matic 400 (California)
CWT 454 LS4 275 4-Speed (California)
With the top left corner all that remains, it looks like CWR is most likely. Does this match what is in the car?
It looks like multiple stamps were used to strike those VINs. The trailing 5s do not look identical to me.
Old Mar 25, 2024 | 06:30 PM
elpasorabo's Avatar
elpasorabo
Yes it automatic 400 turbohydromatic.
Old Mar 25, 2024 | 09:31 PM
Pboyd's Avatar
Pboyd
There is no doubt that this is a factory job. It is just very sloppy. It looks like the first vin stamp was above the one running off the pad. Maybe they forgot the change the vin from the previous car. It was mostly ground off but still a little visible. Unfortunately they took most of the Tonawanda R off with it. Then the vin was stamped again, but they placed the stamp too low and part of the numbers ran off the pad. Finally it was stamped the third time to the right of the mess they had made of the first two attempts. It was ok for production on a moving assembly line, but it looks bad to car collectors 50 years later. Don’t worry about the last 5 of the vin being a little out of line. The holders were not real tight and the pieces of type forming the number sequence could wiggle a bit in the holder. This is the original engine. It is just very unusual that the vin took three tries.
To Block numbers
Old Mar 25, 2024 | 10:01 PM
barkingrats
With Christmas and New Years thrown in, it appears to be an acceptable time frame from engine build (12/21/73) to VIN assignment (~1/12/74). I think it looks like VIN stamp # 1 shows the remnants of 1 125 of the other two stamps, so who knows why it was ground out.
One of the comments on the NCRS forum is that the T stamp is too close to the pad's forward edge. The Tonawanda BBs were stamped before the heads were installed, so the stamp is typically further from the pad edge. In general I see their point, but it looks like a typical BB stamping to my eye.
Whoops
After a few forum searches on '74 LS4 casting numbers, it seems the chart above is incorrect in that it should also include Corvettes through '74. 1975 and after did not have a BB offering. This site shows this: https://corvettec3.ca/casting.htm
Old Mar 26, 2024 | 12:03 AM
drwet's Avatar
drwet
That is absolutely an original stamp. Only the factory would screw it up that bad.
Old Mar 26, 2024 | 05:55 PM
gbvette62's Avatar
gbvette62
As everyone has an opinion, I'll add mine. I think it looks factory, including a factory ground out.
From what I see my guess would be that at St Louis the VIN derivative was initially stamped over the engine suffix code. Someone then decided that it needed to be moved so it was ground out and restamped, but then the pad was missed when the second stamp was done (maybe the guy stamping it was pissed he had to do it again and wasn't paying attention?). A third stamp was then done further to the right of the engine stamp without first doing another grind out, to make sure entire VIN appeared on the block. I came to this conclusion because the ground out took out a portion of the suffix code, and the last two digits of the VIN (25) can be faintly seen over/behind the "14" in the full VIN stamp. If it's a restamp, they're the best reproduced broach marks I've seen on a pad yet. This is my guess, for whatever it's worth?
The 3999289 block was used in a number of 454 engines in 72-74 Chevrolets, including the 72 Corvette LS5 and the 73-74 Corvette LS4.
