Main Fuse Size?
Old Mar 27, 2024 | 05:52 PM
K-Dog's Avatar
K-Dog
Default Main Fuse Size?
I’m installing a Vintage Air system into a base 71 C3 w/o AC, no power anything, or any other power modifications. The radio draws about the same as OE.
I’m planning to run a power wire off the battery to a small 4-wire fuse block in the battery space and I want to put a fuse between the Batt and that fuse block. I have a Blue Sea terminal connector that takes from 3-300 amp fuses.
As of now, the only thing that will run off the block is the Vintage Air, which gets a 30 amp fuse.
What size fuse would be reasonable for the Terminal block? 50? 100?
I may add a couple items to the compact fuse block later, but don’t have plans for anything that would draw a ton of amps - maybe a small power amp for the stereo if it needs it. (I prefer engine sound most of the time!)
thanks for your thoughts on this
Old Mar 27, 2024 | 06:37 PM
Richard454's Avatar
Richard454
Fuse size is determined by the wire size. You want the fuse to blow before the wire melts. See chart below-
You can always run a smaller fuse-
You want the fuse as close to the source ( battery ) as possible.
At each junction where you change the wire size- you will need to fuse that wire accordingly.
The other thing- make sure you use cross poly link insulated wire -rated for under hood temps (256º) NOT the "primary" wire you find at the autoparts store ( only rated at 180º)
