cooling fan temp sensor pigtail
Old Mar 27, 2024 | 11:09 PM
pete315's Avatar
pete315
Default cooling fan temp sensor pigtail
On my 81 right head between #6 and #8, there is a 2 prong temp sensor that controls the auxiliary electric cooling fan. I need a new pigtail connection. My original plastic connector was so brittle it just crumbled apart when I tried to remove it from sensor to check operation of the fan. Fan does work if I ground out the blue wire. Not really sure where the black wire goes or its purpose. Does anyone know where I can get this 2 wire pigtail. I can't find it anywhere. Thanks.
Old Mar 28, 2024 | 12:12 AM
aznd's Avatar
aznd
try lectric limited - they manufacture most of the C3 wiring harnesses. maybe they can help you identify?
