Driveability- High Compression 454 LS5
Thanks for the insight!
I'd always choose the big block, but then, I'm a snob in that way. The torque of the 454 is amazing compared to the small block, but rear gearing will play a big role in comparing the performance of the two cars.
The engine will run fine on most pump gas that's available, and putting an "aftermarket" timing curve in the distributor will help (noticeably) with both summertime engine cooling and everyday fuel consumption.
My take, but by the mid 70's after the oil embargo, the later C3's all came with the 350, and would try to find one of the early C3s that came with the factory big blocks isntead. Ones with the 427, or god forbid, the L88, going to cost an arm and leg, and so if you found one with OEM LS5 or LS6 454 that is not over priced, would go with it.
Hence the later C2's was the years that the vet went from a light weight racer, to pretty much a muscle car drag strip king with the big block motors. During the C3 years, car started as more of a muscle car than the later C2, then when the price of fuel went up around 73 after the fuel embargo, gas guessers were not long selling and everyone wanted a car with high MPG, and why the later C3 all got the 350's pretty much instead.
Note, was not until the C5 Z06 that the corvette returned to a balance handing machine with higher power output again.
Myself, would be looking for a C2 with 327 motor,since corner flicker like you would not believe since lighter, the 327 loves to rev fast with more then enough power, and if you get caught in the snow, the shaker rear end works very well for that as well.
I appreciate the comments on the big block, pretty much what I wanted to hear. I'll be going for the '70 LS5. Will post photos when I bring her home.
I use 94 octane and have also used 91 octane on a couple of occasions with no ill-effect.
It's a beast of an engine. Good luck with the purchase.
So for me, C2 with small block 327, and if going for a C3, then go big block all the way, with 427 the first choice (any of them), then 454 the second.
The 454 was more of a sup'd up truck motor that pulled harder off the bottom, while the 427 love to rev hard and fast all the way to red line instead .
Same for the 350, verse the 327 too.
Hence in a sports car for higher rev'g use, bigger is not always better, with the 327/427 the better motors over the 350/454.
