Headlight replacement - help with washer sprayer
Apr 10, 2024 | 01:07 PM
I have to replace a headlight on my 1969 Corvette.
I popped the headlights up and removed the screws from the bezel but got stuck on the washer sprayer.
How do you detach / get around the washer sprayer to pull the bezel off the headlight assembly to get at the headlight?
Apr 11, 2024 | 01:04 PM
You cannt raise the bezel high enough to get an open end wrench on the nut holding the nozzle?
Apr 11, 2024 | 01:09 PM
Quote:
Originally Posted by
MelWff
I'll try that - thank you.
Apr 12, 2024 | 03:51 PM
SKeough
that's the reason the lower washer was moved to the vertical position .
Apr 12, 2024 | 04:17 PM
dennis
Is raising the bezel high enough to get an open end wrench on the nut holding the nozzle the only way to do it?
