Hey, I want red line tires, but they are too expensive. Has anyone ever used or does anyone know anything about the 125.00 kit on amazon to put the red circle on? It is called
Tire Stickers Red Line Tire Add-On Rubber Stripe Kit
2016 C3 of Year Finalist
I put them on my cooper cobra tires. You need to find a line on the tire so you can follow it all the way around so it wont look off center. I followed a line and taped the tire sticker on to make sure it looked good. When I was satisfied I sanded the tire like you would to fix a bicycle tire. the applied the glue and the tire sticker. Looks great and have been on there a couple of years now. If you follow the directions they provide to determine the size and to apply them you will do fine.
before being sanded and cleaned with acetone....i used the line under the logos
applied and taped down
peeling the protective label and reapplying the tape
I think this is the ones I ordered...looking in my past orders
