69 exhaust
Old Apr 29, 2024 | 10:32 PM
Mobifire's Avatar
Mobifire
Default 69 exhaust
Alright in todays wonderful post I have a 69' small block manual and i bought all new 2inch exhaust pipes and magnaflow mufflers from corvette central. I have had a bear of a time trying to get my exhaust tips to come out straight. Any tips/tricks to getting them to point straight back?
Old Apr 30, 2024 | 07:07 AM
69L88's Avatar
69L88
Have you asked CC for advice?
I don’t know the exact geometry of your setup but about the only choices you have is to rotate the mufflers around the pipe to change the plane of the exit to the tips or cut and weld.
Old Apr 30, 2024 | 07:13 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
How the tips exist would depend entirely on the position of the mufflers. Getting the section of pipe the muffler attaches to correct seems to be paramount. After that, cut and weld.
But have to ask, 2 inch exhaust and mufflers???
This is a Corvette? Right?
Old Apr 30, 2024 | 08:40 AM
VERYSOON's Avatar
VERYSOON
Mobifire
A pic would help to see how crooked.
I shimmed the tip to muffler connection with some stainless hose clamp strapping to get them perfectly straight. My 2.5" system came from cc. Are you sure yours is 2"??
vs
Old Apr 30, 2024 | 03:49 PM
Mobifire's Avatar
Mobifire
Originally Posted by VERYSOON
Mobifire
vs
Well it's a small block and came with 2 inch from factory so i just wanted to keep it original size all the way back. I may shim my tips as well because i can get it close but not exactly straight. Are they supposed to splay out a little anyway or do they go straight back? Following the geometry of the back of the vehicle it seems they would be splayed slightly.
Old Apr 30, 2024 | 08:54 PM
PJO's Avatar
PJO
Veteran: Marine Corps
All 69 Corvette's came with 2 inch exhaust system L88 to the base engine.
Old Apr 30, 2024 | 11:26 PM
carriljc's Avatar
carriljc
They should come out pretty much straight. My 2.5" exhaust from Corvette Central parts fit quite well. I'll be putting the Tips on one of these days now...
FYI:
Old May 1, 2024 | 08:36 AM
VERYSOON's Avatar
VERYSOON
If you need to tweak things a bit to make the tips come out straight try using about a 2" strip of a stainless hose clamp. It already has a nice bit of roundness to it.
Work the strip into the area where the pipe clamp is located and just move it around until things are straight and tighten down the clamp. Mine have stayed straight for about 8 years now. The system I bought from CC is the N11 off-road which fit really well.
VS
To 69 exhaust
