Spark Plug Boots Melting
Can anyone give me some advice on what to do, because I’ve heard some people go with ceramic boots, while others found spark plugs that are shorter but still give out max performance. Thank you!
Otherwise there are options for shorter spark plugs, shouldn’t affect performance in any significant way.
BTW...I did use the boot covers like mentioned for a while and they did not work for me either, header tubes too close to the boots. The ceramic boots have now worked perfect for me for the last three years, no issues.
Taylors were fine with stock manifolds and heat shield
Couldn't use the shields with the headers, Burnt through the boot in a few weeks as it was basically laying on the pipe
Tried installing these shields, don't fit
Bought a ceramic boot, can't get it in with the header on, feels like the plug is going to break before it goes around the corner to line up and slide on. Might get on if I loosen off the header but that's not going to happen
Tried a set of accell 8.8 variangle wires with the woven sleeves
Here you can see the pattern from the sleeve heat-pressed into the boot where it burnt through. (I had to slit it with a razor to get it off the plug even though it was greased)
Changed that wire and swapped to a different set of looms to get a little, tiny, itty-bitty bit of room to the pipe and far so good, made it through 2 seasons (ok last year was really really short but still...)
So my take is,,,, the sleeves will work as long as there is still some gap but if it's touching... they didn't really protect the boot. I would suspect ceramic would work but I really would like a gap with them as well, that heat can't be good transferred to the plug out there either
M
