1974 M21 yoke
2018 C1 of Year Finalist
1974 M21 yoke
I am looking for any source to get either a new or used yoke for a M21 corvette. This one is for 1.900 at the base. The bearing is 2.020 OD. This one is either a 31/32 spline. The transmission vin matches the car's vin.
Also, if someone has an option to sleeve it then thats okay too.
Received 4,703 Likes
Cruise-In VIII Veteran
When I needed a yoke for my 77 Super T10 I found one at Zip Corvette's. Perhaps have a look there.
Chevrolet changed the manual transmission late in 1974 from a Muncie to Borg Warner (ST10). Not sure if there is a difference in the yokes or which transmission is in your car, but it is worth looking into before you purchase anything.
Regards,
Stan Falenski
Regards,
Stan Falenski
jimh_1962 (05-03-2024)
I believe the TH400 yoke was the same as the ST-10 if I recall correctly. I think I have one on my shelf to compare.
This is a th400
Then there's this one. Both are sitting on my shelf and I was thinking about throwing them on eBay or something
If it is the same as a turbo 400 yoke here is a part number: Turbo 400 slip yoke 3930827
Look around .... might find a good deal on ebay. you can buy the straps separately too (or you could??) for the turbo 400 yoke 3930827.
So I looked in my archives.
GM part numbers:
Drive Shaft Retainer U Joint Strap:
03882979
U-joint strap bolt:
014018700
And, YES, you can see them on ebay. Hell, you might be able to find them at the gm dealer but I'd check ebay for prices.
https://www.corvettecentral.com/c3-6...26years%3d1974
GM part numbers:
03882979
U-joint strap bolt:
014018700
GM part numbers:
03882979
U-joint strap bolt:
014018700
GM part numbers:
03882979
U-joint strap bolt:
014018700
