Adapter for '76 Steering wheel
Old May 10, 2024 | 11:26 AM
Scott76Stingray's Avatar
Scott76Stingray
Default Adapter for '76 Steering wheel
I purchased a steering wheel thinking I would be able to swap it out like almost every other year, but found out after I purchased it that '76 has a special hub that won't fit most aftermarket steering wheels. I have been to several local shops that all scratch their heads and have no solutions for me to swap out my factory steering wheel. The only solution that has been proposed to me is to replace my entire steering column at a 2k cost. I don't need the column for any other reason so this seems like a really expensive way to accomplish my goal.
I was hoping that someone on this forum knew how to find an adapter or has a solution to replace the steering wheel. I'm open to any and all options!
My current steering column is a NON-tilt basic standard '76. Which is apparently only in the '76, no other years have this column, or at least that is what all the experts are telling me.
Old May 10, 2024 | 02:52 PM
gjohnson's Avatar
gjohnson
Check several Corvette vendors,they have what you need.Ecklers,Corvette Central, Zip Corvette
and others
Old May 10, 2024 | 03:14 PM
Giraffecaster's Avatar
Giraffecaster
Cruising
https://www.topflightautomotive.com/...onversion-kit/
it ain't cheap
here's a video on the basic kit
Old May 10, 2024 | 03:33 PM
Scott76Stingray
@Giraffecaster - This is a way better option than the 2k to replace the whole column. Thanks for the share.
Old May 10, 2024 | 04:36 PM
Scott76Stingray
Damn, I thought I had an option, but this is for Tilt/Tele columns only, they don't have one for my standard column. I'm still hoping someone else has an idea/solution.
Old May 10, 2024 | 06:42 PM
gbvette62's Avatar
gbvette62
The conversion kits are only available for the tilt/tele column. I don't know of any kit to convert standard columns, but I'm pretty sure it can be done. Since the 76 column is similar to the 69-75 standard column I would assume it could be done using the hub and other parts from the top of a 69-75 column. This is basically what the kit to convert the tilt/tele column is, a kit made up of 69-75 tele column hub, bell, etc. The toughest part would be determining what parts at the top of the column are different.
Old May 10, 2024 | 09:27 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
I've never seen a non-tilt-tele 76 but this hub should bolt on.
__________________
Greg
Old May 10, 2024 | 09:34 PM
Bikespace's Avatar
Bikespace
Now you have a reason to upgrade to a tilt-tele!
I'm sure you could come up with a simple adapter if you don't mind a remote-mount horn button
Old May 11, 2024 | 12:10 AM
SEVNT6's Avatar
SEVNT6
Roughly 5000 were built in '76 without tilt..
Old May 13, 2024 | 11:13 AM
Scott76Stingray
Can I get the link or website for this, the URL is cut off on your screenshot.
Old May 13, 2024 | 11:20 AM
Giraffecaster
Cruising
https://www.classicindustries.com/product/3937896.html
i think it's just this one. if you google "3937896 adapter" there's a lot of vendors selling similar
Old May 22, 2024 | 10:04 AM
Scott76Stingray
Another option down the drain, I just got this one in the mail, and it did say it would work for '76 Chevy, but that is for Vega, Buick, and other GM models. But when it came in the mail it specifically mentions Corvette only until '75. I'm really surprised it's this hard to find an adapter, I guess since there are only 4,000 made like this its just too small of a demographic.
I've called all the Corvette vendors, every single one says the same thing, replace the column. Do I really have to replace my whole column just to get rid of this stupid vega wheel?????
Old May 22, 2024 | 11:16 AM
carriljc's Avatar
carriljc
Can you show us some pictures of the fitment issue between your specific column, your old wheel, and your desired wheel? Lotsa folks on this forum with lotsa witty ideas so maybe it's time to fabricate something?
I would probably change the steering column.... lotsa C3s to choose from.
Old May 23, 2024 | 09:28 AM
augiedoggy's Avatar
augiedoggy
My uncle has an aftermarket wheel on his 76 and I believe his is a non tilt (pretty sure of it actually) I know the conversion didnt cost him very much.
I am staring at a horn spring kit I ordered for him I have to install I'll see if I can get pics. ironically it had a smaller cheap aftermarket wheel on it when he bought it and he whined and whined he wanted it to be original... intill he saw how ugly the original vega wheel was.. Its got one of the larger wooden wheels with the chevy logo on the chrome horn button now.
On my 74 I just drilled a few new holes in an aftermarket wheel to get it to line up
Old May 24, 2024 | 12:14 AM
carriljc's Avatar
carriljc
That would be a good find!
Heck - hopefully it is a fantastically simple mod. I'm curious (and I don't have a 76) ....
Old May 24, 2024 | 08:54 PM
gjohnson's Avatar
gjohnson
I have a 76 and I really am baffled why people hate the wheel so much.
To Adapter for '76 Steering wheel
