Yellow Spots Bottom of Engine
Hi...new to the forum. Short story, I inherited Dad's 69 Vette that's been sitting for 35 years. Beginning a slow restoration. The oil pan was removed and I was surprised to find yellow spots and coloration on the bottom of the engine. It's all dry...the oil was all drained years ago. I thought it might be paint, but concerned it might be moisture residue. Can't find anything online and was hoping experienced Vette owners might have some insight. Any info would be appreciated. Thanks!
Are you disassembling the engine before cranking it?
if not, you should spin that oil pump via the Distributor shaft to pump oil to those bearings.
I used a cordless drill and got good flow up to the rocker arms.
I’m sure you already know that, but just making sure.
How about a full pic of the car?
I would also remove the spark plugs and squirt a generous amount of Marvel Mystery oil into the combustion chamber to lubricate the rings.Let it sit for a period of time. Do that before you hand crank the engine. I agree with the above, post a few pictures of the car. Jerry
1967 Pedal Car Champion
Have you looked under the valve covers for it?
I think if it were mine, and it doesn't easily rub off, I'd send off an oil analysis after an hour of run-time just to see if it's coming off into the oil (and maybe get an idea of what it is). Send pics to the analysis company too.
Seems like it could be factory paint. This is a 1980 L-82
Factory blue colored paint on a crankshaft. Rods have pink paint but harder to see here.
Another shot showing factory paint on a crankshaft with the oil pump and baffle removed.
