1975 Rear Diff Rebuilds
I read the Zip does it also for $700, has anyone done that? How did it work? Not sure I want to pull the diff off myself. Never done it before. Is it complicated?
Or is it easier to just buy a rebuilt diff and install it?
I wonder if that's who Zip sends them to.
If you are willing to drive to Ojai, I have a gentleman that has been rebuilding rear ends almost his entire life and he's 80.
He actually had a shop on the Ventura Avenue that specialized in rear ends.
He's rebuilding a couple of mine.
PM me if interested. I can ask Mump (his name) if he would do it for you. Certainly cheaper than shipping it to Zip and paying them $700
He said that if the rear end has some camber it could be the suspension pushing on the half shafts I think he said, which could cause the issue. So basically the whole rear end might need to be gone through, bushings, half shafts etc.
I told him the rear doesn't seem to have any camber, but it has some clunky sound when going slow in reverse and in first gear. He told me to try and change the rear diff fluid and add Friction Modifier XL3 which is a ford product. He said don't use the Chevy stuff. He said that might fix the issue and save me $900+. After researching the XL3, it did fix similar issues I am having.
Called the local Ford dealer, they have it. So going to pick that up with some gear oil and a lubricant suction gun after work and give it a shot. Fingers crossed!!!
- What is done to the diff?
- Is it built to application? if so how.
- What parts do you use- a kit from any supplier, NAPA, etc
- What is checked in the diff?
- Are new gears part of the build? if so what brand, are there any better than the others or will the cheapest gear set I find on ebay be the same?
- What is gear break in?
- Are there different type of parts- like axles, bearings, etc
- Do you rebuild the posi, do you know what posi is in it and what parts are used?
- Is there anything to be checked or done to a posi?
- Are there clutches in the posi and what type? If there is more than one type which one do you use and why?
- Are any special procedures needed to build the diff or are you just looking at the GM overhaul manual?
- What is tuning a posi or polishing a posi?
- Should there be any endplay in the axles, if so how much? Is there such a thing as too much or not enough?
- Are you a racer?
- How much time do you expect it to take and do you flat rate the labor or charge per hour? at what rate.
- How much abuse will the diff handle when you're done, do you warranty anything? as I leave your shop I will light up the tires and see.
Good luck.
- Are you a racer?
Good luck.
AND......................there ya go / from the TUSHY gooooh rooooh himself !!
- Are you a racer?
Good luck.
Great information, thank you! I drained and refilled the fluid last night and added some friction modifier, took it for a spin, did some figure eights to get the fluid moved around and didn't feel any of the clunking I did before when going in reverse or in first gear at very low speeds. Fingers crossed. If it comes back or I guess is still there I will definitely take your advise!
