C3 Hardtop Storage / Moving Cart
I used a furniture dolly as the base. The dolly is 18" x 30", Harbor Freight has it for $18, and it is a perfect size for your base. A couple pieces of 1.5" pvc, 4 90 degree elbows, 6 T's. Some 3/4" screws, PVC primer and cement, a couple pool noodles, and zip strips and VOILA. It's done. Of course the PVC is firmly attached to the base, so that it is a one-piece unit... with better casters than the store-bought cart.
So, it's not great, it probably doesn't look as nice as something that is machined, but it works well...and if you are even the slightest bit handy, or have some of this sitting around, it can be done pretty cheap. For what is is worth, I have seen folks put their top on the cart similar to how I have it stored now, I have seen others turn the top so that the 'inside' is what is resting along the top bar of the cart. This cart setup allows you to easily store the cart either way, and the pool noodles allow it to stand firm without sliding at all. Of course a blanket or cover of some kind is (and should be) used.
Opening it up to all of you. Honest feedback is appreciated. I had an idea to add a bungee or strap to connect from the center of the top bar, around the top, and then connecting to the cart. But it doesn't seem to be necessary, but it may help to relieve some of the 'strain' on the taller side of the cart. Likewise, I could make the tall side shorter, to also reduce some of the strain. But, so far, so good.
And Yes...run a long bungee cord over the top of the hardtop "just in case".
Now, spend that money you saved on shiny stuff for your Vette
Sounds interesting, for sure. I was a little concerned initially, because when you set the top down and it starts to 'lean' into the taller section, it does 'give' just a little bit. But I used pvc cement on all joints, and double screws on each connection as well. I was going to use a strap to go from one side of the cart, up and over the top, then down to the other side of the cart. I am figuring that this will actually 'snug' up that taller section just a bit more. Hqvent done it yet, but I will reply back. I will also see if I can find a way to estimate how much that taller section is 'giving' when I place the top in it.
Yes, I was a little concerned the first couple times I put the top in it, but I have no reason to be suspicious at this point, because it seems fairly secure, and the amount of 'give' isn't that much.
