Headlight vacuum wits end!
Old Jun 23, 2024 | 02:29 PM
JC 78 Vette's Avatar
JC 78 Vette
Default Headlight vacuum wits end! - SOLVED!!!
I know there are MANY topics on this but I have searched endlessly. I’m also a new owner so forgive me
1978 C3 winking. Passenger side won’t come up. Tested vacuum system with gauge, getting 22HG up and down line all the way to yellow hose at relay. Thought it was relay issue, so have brand new relay. Don’t think the tank has leak as driver side pops up easily. Actuator ‘seems’ ok? That is last thing I can think of that is issue, but I have performed these tests:
- when headlight is pushed up manually and car is running, goes down no problem when I push in switch
-Blow into red line (into back of actuator) and headlamp goes up!
- with car running, have pulled out both green/red hoses and plug, try pushing headlight up/down and get good resistance
- validated 20hg at all inputs at relay/actuator area
What am I missing???
EDIT: Solved! It was the vacuum seal at the relay…completely torn! $9 dollar part replacement and now both headlights pop up super fast!
Old Jun 23, 2024 | 03:17 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Try this test. You should have 2 actuator relay valves, one for each actuator. Either run a tee so you can run both actuators off the good side relay valve or swap the relays. It will tell you if it's the relay valve not working which is usually the issue.
Old Jun 23, 2024 | 03:41 PM
JC 78 Vette
Ok I can try that. I bought a new relay for that side though I suppose it’s possible it’s faulty? Any other tests for the actuator I haven’t performed?
Old Jun 23, 2024 | 03:46 PM
Rescue Rogers
You can put vacuum straight to it but from what you said the actuator is fine. I've bought new relays that were garbage out of the box....they are cheap Chinese junk
Old Jun 23, 2024 | 06:58 PM
Paul71LT1's Avatar
Paul71LT1
Along the same line of thinking as the suggestiong from Rescue Rogers, I would try swapping the "open" lines from the relays to the actuators so the right relay feeds the left headlight and vice versa. If the "wink" switches to the opposite side then it is the relay that is at fault. If the problem remains the same then the relays are good and it is the actuator that is the problem.
Old Jun 23, 2024 | 09:21 PM
JC 78 Vette
Well, I isolated the good side by capping that vacuum and then moved the hoses on the side I’m having issues with to the relay I know for sure works and it “tries” to open but can’t. It must be actuator or seal in that actuator. Not sure why it passes other test such as when I blow into it it opens or closes when I manually open and shut off lights but oh well.
Old Jun 23, 2024 | 10:47 PM
Eliredandblack's Avatar
Eliredandblack
If your vacuum actuators are OEM there is a guy who will restore them, probably better idea than buying the Junk ones sold by all the Corvette Suppliers.
Old Jun 24, 2024 | 12:40 AM
JC 78 Vette
Going to try to replace rod seal and hopefully keep actuator. $8 repair hopefully 🤞
Old Jun 24, 2024 | 04:45 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Just yesterday I helped a friend rebuild both his headlight actuators. Badly blown seal on one. But we pulled both and put seal kits in both. His headlights go up and down again!
Hopefully you will get the same results!
Old Jun 24, 2024 | 09:58 PM
Bikespace's Avatar
Bikespace
Have you considered either an electric or manual conversion?
Get the electric kit here (Made in USA!):
https://www.ebay.com/itm/155261365162
The manual swap is a bit cheaper, though it may be easier to remove the hood to get all of the vacuum trash out of there.
Old Jun 24, 2024 | 10:11 PM
JC 78 Vette
I want to keep the Vette as original as possible (aka I’m too cheap )
Old Jun 26, 2024 | 10:44 PM
JC 78 Vette
Solved!!! Vacuum actuator seal was ripped!! $9 replacement and now they both pop up super fast!!!
Old Jun 27, 2024 | 03:53 AM
4-vettes's Avatar
4-vettes
Whooo Hooo! Glad you got it! Don't understand how you missed it with a vacuum guage, but you got it!
Old Jun 27, 2024 | 01:10 PM
HCK's Avatar
HCK
Default vacuum actuators restorer
Can you please let me know who the restorer is?
Old Jun 27, 2024 | 02:42 PM
Eliredandblack
The restoration guy is Robert Demmel, below is his contact information.
Old Jun 27, 2024 | 03:32 PM
HCK's Avatar
HCK
Much Appreciated!
To Headlight vacuum wits end!
