Battery light is on
Old Jul 16, 2024 | 08:48 AM
frankenbro's Avatar
frankenbro
Default Battery light is on
The battery light is on and the battery is fully charged 12+,the alternator is pushing out 13+.
Old Jul 16, 2024 | 11:20 AM
MelWff's Avatar
MelWff
Check the connector with the two wires
Old Jul 16, 2024 | 12:41 PM
carriljc's Avatar
carriljc
take a voltage reading at the battery terminals in the following condiitions:
1. engine off, no loads energized.
2. engine idling, no loads energized.
3. engine idling, max loads energized.
4. Rev engine up to about 1100-1200 rpm and get another reading.
We can then evaluate what is going on.
Old Jul 16, 2024 | 05:02 PM
frankenbro's Avatar
frankenbro
12.07 at off
14.43 at idle
14.49 at 1500 rpm
Old Jul 16, 2024 | 05:08 PM
frankenbro's Avatar
frankenbro
Default Under load at idle
11.80 - 11.98 with lights, radio, wipers and AC on
Old Jul 16, 2024 | 05:09 PM
MelWff's Avatar
MelWff
Originally Posted by frankenbro
12.07 at off
14.43 at idle
14.49 at 1500 rpm
The 12.07 is low.and the alternator is trying to bring the voltage up. A fully charged battery is 12.75 and 12 is already 25 percent charged.
Old Jul 16, 2024 | 05:31 PM
frankenbro's Avatar
frankenbro
ok I’ll charge it up and see what happens
thanks
Old Jul 16, 2024 | 07:04 PM
carriljc's Avatar
carriljc
frankenbro
Here you are-when at idle the voltage at 11.80 - 11.98 with lights, radio, wipers and AC on is LESS adequate---- it is actually downright shitty. At idle your alternator is not adequately charging and the battery is slowly getting drained down.
I recommend not ******* around and just going to a 140 amp CS-144.
Your profile is not filled out but methinks from your avatar that your car is a 1982? Your wiring should be adequate. Lotsa posts on here on how to convert....if you cannot find just ask.
I am in the process of converting my CS-144 to a DR44G....but I have not finished .... but if you wanna try...here is that post I have NOT made much progress on just because......
https://www.corvetteforum.com/forums...xperiment.html
Old Jul 16, 2024 | 08:19 PM
frankenbro's Avatar
frankenbro
frankenbro
Yes it’s an 82
I charged the battery, now I have
12.75 off
14.42 idle
14.50 at 1500 rpm
12.33 under load
the light is still on.
Old Jul 16, 2024 | 08:28 PM
MelWff's Avatar
MelWff
Yes it’s an 82
12.75 off
14.42 idle
14.50 at 1500 rpm
12.33 under load
12.33 under load is not charging. What load?
Old Jul 16, 2024 | 09:03 PM
frankenbro's Avatar
frankenbro
lights, wipers, AC and radio
Old Jul 16, 2024 | 09:51 PM
MelWff's Avatar
MelWff
Your alternator should be tested at auto parts store, I think it's bad.
Old Jul 16, 2024 | 10:20 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Your under load voltage is way to low. That's why the light is on. Stator in the alternator is likely breaking down. New alternator.
Old Jul 17, 2024 | 09:24 PM
frankenbro's Avatar
frankenbro
It was the alternator. Napa tested it for me and believe it or not it was under warranty. Free replacement.
Old Jul 17, 2024 | 10:15 PM
4-vettes's Avatar
4-vettes
How good is that!
Old Jul 18, 2024 | 11:51 AM
carriljc's Avatar
carriljc
Optimum!
To Battery light is on
