New To Me. 77 C3
I want to get this thing going. Here's what I have in mind, let me know if there is anything else I should be looking for or at that is problematic with these cars after sitting for 16 years.
1. Make sure engine is free and not locked up.
2. All fluids changed, oil, antifreeze, brake fluid, etc.
3. Fresh tune up? Just had done before it sat.
4. Brake job all around. Calipers, pads, rotors.
5. Drop gas tank and drain and inspect inside for rust.
6. Battery.
7. Drop oil pan and clean.
Now I am no master mechanic, but all of these tasks are within my wheelhouse. Any insight in the order I should tackle these would be helpful. Let me know if I am going overboard or not far enough. Thanks in advance. And it great to be here.
Good luck on your ‘77.
Electrical would be one, just due to age.
Check the seals of the t-tops, if dry rotted, they will need replacing as it will cause corrosion issues if leaking.
Would recommend getting AIM, that is an assembly manual.
your list looks like a starting point.
Most commonly complained about issues on here? Steering and brakes I would think.
Clean carburetor.
Hope you enjoy it!
Love the "sugar scoop" C3 coupes.
I bought a new 1977, 47 years ago. An L82 AT. MSRP was $10,900.00. Out the door after discount was $9,600.00
"All Corvette's are Red"!
2 - even though they have a ton of tread left, those tires are unsafe to roll at speed, replace immediately
I'm new to owning C3 but they don't seem to have so many "gotcha!" gremlins that are unique to the car mechanically. Fuel sending unit/pickup sock is in the bottom of the tank so you don't even need to drop the tank. You can drain/inspect easily from the top.
If you enjoy revival content, check out Vice Grip Garage on youtube and you can see the order he approaches on vehicles that have been sitting unused.
4. Brake job all around. Calipers, pads, rotors. <<<<< See comment below
6. Battery.
There's a guy who comes to our local car shows...he's got some like very early 90's tires on his classic car! They might even be late 80's! And they look perfect. They look great. Not a single crack or dry rot on them. He drives it all over! I fully understand how tires go and delapidate..(I've had a few do that). I'm not advocating that at all. Just something he and I joke about. Some of those older tires they must have used a different compound on them that wasn't as prone to rot. You buy a new set of Michelins...and they'll be cracking in about 3 years.
I only ever put WD-40 to spiff up the shine on my C/Cars' tires (after cleaning the white walls with mild soap). No silicone products touch my cars anymore (been around that block!). The tires still look fantastic. So does the interior.
