Remove minor guages to replace lights?
need some help, this is for a 1972. recently purchased some led lights for the dash guages, and thought Id do a trial run of getting the guages panel out, halfway through realised that the bezel surround is cracked through on the passenger side. So…
1) is the bezel easy enough to remove from the panel or does the whole gauges assembly have to come out now to refit a new bezel?
2) what are the best ways to get access to change the lights in the gauges. Is there a step by step procedure or youtube specific for a 1972 dash?
just thought Id add, I'm no mechanic, just willing to give it a go.
many thanks
Matt
All to downgrade to LED's.
It really isn't that difficult to remove. Take your time, be careful. Those 2 nuts on the bottom are a bugger.
many thanks
Matt
That video by caskiguy is good to watch if you've never done it.
It's easy. Don't stress..... here are the directions---- I would not try to remove the center bezel without removing the passenger side dash panel. Probably end up breaking the top section off......I broek mine, of course, once I had broken mine it make everything a lot easier, but still, remove the passenger side dash panel first.
1. remove the passenger side door sill
2. remove the passenger side kick panel
3. remove the passenger side dash pad
4. THEN remove the center bezel...... easy does it..... super easy to break at those weak corners.
PS- LED lighting is fantastic.
many thanks
Matt
https://www.corvetteforum.com/forums/c3-general/4731686-gauge-cluster-removal-help-on-75-a.html
DISCONNECT THE POSITIVE BATTERY CABLE
