Blessed with a vett
Old Aug 24, 2024 | 05:09 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
OIl pressure is fine. Use a good oil that has high zddp. I like mobil1 15/50 or vr1 20/50. you need the high zddp for the cam lubrication and the med/high viscosity will keep the oil pressure up in old engines. Its good protection and no other reason to go lower.
Look at your tach and see if it has a cable off the back, if so uncsrew it to disconnect it and spin the cable and see if the tach moves. A quick twist will make it bounce. If not you need a new cable and you can may need to pull the pieces out of each end. those cables snap veery easily now a days
Old Aug 26, 2024 | 09:23 PM
BarrelCurve's Avatar
BarrelCurve
Welcome to the fun!!!
Yea, this forum software isn’t the best, but it works well. If you want to search something here, do a google search of this site. You’ll get better responses from that than the internal search… 😉
I had to do a couple practice posts to figure out pictures. 🤣
