74' 454 Engine parts value? Help
Old Aug 31, 2024 | 09:53 AM
Jetglow's Avatar
Jetglow
Default 74' 454 Engine parts value? Help
I have several parts off my 49,000 mile 1974 Mark IV engine.. Im trying to figure out value so I can fairly price them for sale...or keep.
The the only thing I am keeping/using is the block itself.
Old Aug 31, 2024 | 10:31 AM
69L88's Avatar
69L88
Unlikely their sale will allow you to retire early but it would be a lot better if you listed what you have.
Old Aug 31, 2024 | 10:43 AM
Jetglow's Avatar
Jetglow
Original crank
Heads
Intake
plus associated nuts and bolts
Q-jet
Starter
Distributor/coil
Old Aug 31, 2024 | 12:12 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by Jetglow
Original crank
Heads
Intake
Q-jet
Starter
Distributor/coil
Except for the crank, those parts would have value to a restoration but they'd need to be original numbers to an '74 LS-4 and not replacements. When you list the heads, intake, starter, and carb, include not only the part number but the date code. The distributor should have an aluminum band with # around the housing just above where it's clamped down. The coil should have a debossed number on the side. All of these things will get you more $ than if you don't include the details.
The crank isn't worth as much because it's not a visible part.
To 74' 454 Engine parts value? Help
