Interlock cable installation question
Old Sep 9, 2024 | 06:13 PM
kansas123's Avatar
kansas123
Default Interlock cable installation question
This cable is killing me on it's installation. It's new and very stiff and I am not able to get it installed. I tried transmission end first, steering column end first, just ain't happening. Can someone / would describe the magic installation process for me; seems there has to be one. (do you have to remove/loosen the bracket where it connects down by the transmission, thereby making a new mess on the garage floor?)
Thanks. It's a '72 automatic.
Old Sep 9, 2024 | 06:22 PM
Mooser's Avatar
Mooser
If you leave is off up top where there's a little more cable exposed from the sleeve so you can fight (bend) it a bit more than down at the transmission
Also don't forget the shifter can be taken out of park and put between park and neutral wherever to get the cable onto the pin.
M
Old Sep 9, 2024 | 07:53 PM
kansas123's Avatar
kansas123
That's fantastic M. Thanks a lot.
To Interlock cable installation question
