Hooker hitter side pipes 82 Corvette
Old Sep 12, 2024 | 05:40 AM
Uncle gingi's Avatar
Uncle gingi
1st Gear
Default Hooker hitter side pipes 82 Corvette
Trying to put new mufflers in. I read some of the info but the mufflers look like they're really stuck in there hard, but there's also a piece in The collector piece from the header. How do you remove these items so it's basically two items a side pipe has whatever is in there. I don't know a muffler or something and then the collector piece has a honeycomb shaped thing that when you put the side pipe on the muffler like sits together with the other piece inside the collector pipe
Old Sep 12, 2024 | 06:08 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Sounds like a really good explanation.
removing baffles that have been in for awhile can be really fun sometimes. But it sounds like your all over it.
Try a slide hammer with a hook for removal.
If it was easy everyone would be doing it!
Old Sep 13, 2024 | 03:39 PM
TCracingCA's Avatar
TCracingCA
Dupe post
Old Sep 13, 2024 | 03:40 PM
TCracingCA's Avatar
TCracingCA
Once they are rusted together or just stuck, near impossible to get them apart without damage.
We do this to our cars, here is our blue car, where we weld a flange on the part that slips in and a flange on the side pipe header collector!
Old Sep 13, 2024 | 06:44 PM
pltmgr's Avatar
pltmgr
I have Hooker side pipes on a 68 and 71. I gave up on both of them. Every once in a while I give to anther go but to no avail. Ive tried heat, cold, twisting, banging etc.
Old Sep 14, 2024 | 12:28 PM
Sayfoo's Avatar
Sayfoo
The mufflers can get stuck because of rust or carbon build up.
The trick is to use a chain and a piece of bar or pipe and insert it through the muffler to flop out on the exit end of the muffler. Kind of like a toggle bolt. Then I secured the other end of the chain to a tree so I could slam the muffler pipe like a slide hammer.
Mine took a lot of work.
An extreme idea would be to cut open the outside pipe where it wouldn't be seen, then weld it after you got the muffler out.
Old Sep 17, 2024 | 12:24 AM
68/70Vette's Avatar
68/70Vette
The muffler should be made of stainless steel to prevent it from rusting.
Old Sep 17, 2024 | 12:44 AM
4-vettes's Avatar
4-vettes
Great plan! Now to convince the manufacturers of this!
To Hooker hitter side pipes 82 Corvette
