Can someone provide me with the procedure of adding a pic to a new thread???
Been on here a long time and never had cause to post one.............until now that is!!!!
left rear wheel is somewhat out of kilter tilting in to the top fender looking from t
To all C3'ers:
I was recently told by a few guys at our weekly breakfast gathering that the left rear wheel is somewhat out of kilter tilting in to the top fender lip looking from the rear??
It is a 78 SA!
Any and all inputs for repair etc are welcome
Pls let me know if I've left out anything?
You need to be in full edit mode not quick reply. If you are in the middle of a thread hit "Reply" at the bottom of the message, then you will see "Manage Attachements" at the bottom of the reply window. Click that and a new window opens which you can drag and drop to or select from your files. If its a new thread the manage attachments button should be at the bottom of the window you are starting the thread in.
