Things to do with Rad out?
Old Oct 12, 2024 | 12:23 PM
JC 78 Vette's Avatar
JC 78 Vette
Default Things to do with Rad out?
Hey all, waiting on Rad fix and wondering since I have the Rad out of the car and I ain’t doing any driving, anything to check or fix while I have it out and room to work?
Old Oct 12, 2024 | 04:24 PM
interpon's Avatar
interpon
I detailed rad support..many rust there..i was very fortunate to not have any. Lots junk will be there and want to keep dry, touch up anything that looks like rust. Clean condenser etc..
Old Oct 12, 2024 | 04:36 PM
Mark G's Avatar
Mark G
The radiator side-seals (foam seals) often get old and brittle. Break, fall out or are disgarded. Those are hugely important in the cooling of a corvette as they prevent the fan from pulling in air from the sides of the fan shroud (and not *through* the radiator itself). If your are missing or bad, now it the perfect time to replace them.
Check the water pump for any 'play' in the bearings.
Inspect hoses. If brittle or looking 'puffed-up' consider replacing. Make sure there's a spring in the lower radiator hose.
Nows a good time to stock up & install new coolant. You were probably going to anyway. Use distilled water (not tap water). Or buy pre-mix.
Anything else up front that looks suspicious. ...Lube suspension while you're at it.
That's about all I can think of.
Old Oct 12, 2024 | 07:17 PM
Piersonpie's Avatar
Piersonpie
Take the body off
But seriously, everything else already said in this thread, and the vacuum lines for the headlights.
Old Oct 12, 2024 | 07:56 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Originally Posted by Piersonpie
Take the body off
Old Oct 13, 2024 | 11:27 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hows the timing chain?
Old Oct 17, 2024 | 07:26 PM
LT1M21Vette's Avatar
LT1M21Vette
Upgrade to a 3/4 race cam?
Old Oct 18, 2024 | 04:14 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking,..... put the rad back in.
Car will go much further with rad back in.
Old Oct 18, 2024 | 10:10 AM
Z0Tex's Avatar
Z0Tex
Cam swap!
Old Oct 18, 2024 | 11:07 AM
piste's Avatar
piste
Banned Scam/Spammer
heh...that's how it started for me three years ago. Car sat 20+ years prior...copper rad needed recore...so out it came along with support. Next thing I know I am down to the frame on a "body on" restore. All drivetrain and suspension is out except engine and tranny. Getting ready to begin the reassemble. So you could do all that....or....just what has been posted already....things that are hard to access with the rad in....which is a lot actually.
To Things to do with Rad out?
