Hey Everyone. I bought my corvette with a crate engine already installed by the previous owner. The break-in instruction sheet that came with all the paperwork states that use of synthetic oil is not recommended until the engine has at least 6000 miles. I’ve been using conventional with zinc for the previous few changes but was going to switch to synthetic this next time. My question is, what is the reason for such a recommendation on a new motor? Thanks to anyone who can explain.
Seating of the piston rings. Synthetic may lubricate too well to insure good seating, depending on the ring face surface and the cylinder prep. OEM's can prep a cylinder much better than aftermarket and use moly faced rings that seat almost immediately, so they do not require conventional oil for break in.
Although given the oil consumption problems that OEM's are experiencing and have been for over a decade, I believe they have moved too far in the direction of not needing a break in.
The zinc based oil is important if you have a flat tappet cam. I have a flat tappet in my rebuilt L82 and run Valvoline VR1 since it has the recommended zinc.
They probably figure two oil changes I'm guessing. W/o knowing how anyone is going to drive their particular car (engine), 6k probably covers most contingencies (by the rebuilder). I think there's a bit of SWAG when coming up with a number like that.
It depends on how it's broken in. Personally I warm an engine up to full temp, make sure the timing is right, then accelerate hard and decelerate aggressively for a good 50 to 100 miles. Then change oil, still conventional drive it hard for the next while.
then next change at 3000 to synthetic.
At 6k miles, if the rings aren't seated, they probably will never be.
Roller lifters? Definitely switch. Synthitic better all around.
Flat tappet? Depending on spring pressure????
you can still use synthetic, just be sure zinc is adequate.
6k could be min for certain ring type spec.
I have seen 10-15k numbers.
Important to work rings both ways
1, under power to expand in downward direction
2, under decell/eng braking to expand upwards.
ex. low gear slowing from high speeds.
I have a 72 LT1 with flat tappet lifters/cam I see that they do not seem to be selling Valvoline 20 50 racing oil in my local auto parts stores anymore except for one quart at 10 bucks each. How would one keep the proper zinc with synthetic oil? Many thanks
2016 C3 of Year Finalist
Just wanted to get your name straight so when you are wondering why your cam is flat we can give you a good answer....does your crate motor come with a warranty? does it have a roller cam? Why dont you want to follow simple instructions? You can call the manufacturer for the answers
Calm down there big guy. My motor has hit 6000 miles so I am following instructions. What I was asking for was an explanation as to the reason for such protocol, because this is a forum for people to learn. Thanks for the feedback.
I am with you and just curious too. Why do you want slippery to help the cam but not slippery for the rings? Seems to be conflicting objectives. There are probably a bazillion answers on the web but getting to the bottom of it can be exhausting. I'll listen on the sidelines if someone has a quick answer.
Rings are not like bearings. Bearings ideally never touch metal to metal, there is always a film of oil between surfaces.
Piston rings on the other hand HAVE to touch the cylinder wall and actually wear into that cylinderwall surface on a microscopic level. This is done to insure sealing of combustion gasses above the top ring and oil below the bottom ring. If this is not done properly you will end up with combustion gasses in the crankcase area and oil in the combustion area to an excess. Both of which cause problems with engine running. So in order to create the seal as best as we can we allow the ring as to "touch" the cylinder walls.
the cylinder, after it's been honed, has micro high spots that the rings wear into. Once these high spots are worn down it can't be redone unless disassembled and re- honed. If it's not allowed to wear in properly then you get a "glazed" cylinder wall that will not seal properly to the rings and you end up with the associated problems, oil consumption, reduced power, excessive blowby, carbon buildup, etc.
Thanks. So why doesn't the zinc which is added to help the bearing slide mess that up?
Constant high temps and scraping of the rings on the cylinder walls would not allow it to build up to such a degree as to create a lack of sealing during break in. Part of breaking in the rings is to accelerate and decelerate aggressively to force the rings into the cylinder walls, forcing metal to metal contact. The zinc likely does in fact get into the metal of cylinder, the low points. The rings still ride on the high points, or what are left of them at least, constantly scraping the cylinder walls.
