Carpet under sill plate
Old Nov 7, 2024 | 10:18 PM
tkucala's Avatar
tkucala
Default Carpet under sill plate
Does anyone have a photo on how far the carpet extends under the sill plate? I am replacing the carpet in my 1969. Thanks in advance.
Old Nov 8, 2024 | 03:25 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Gezz, never thought to take a photo. But, a bout 1/4 of the way on top. From the inside if that makes sense. So, just around the corner to the top flat side. Approx 1/4 of the way, certainly not even.
Old Nov 8, 2024 | 08:12 AM
robertea's Avatar
robertea
Here is a picture of my 69 when I was working on trying to put my dash back together. Hopefully I will never remove the dash again. The carpet is not the factory carpet, I replaced it a number of years ago, but as I remember it is about the same as the factory. The blue tape was to hold it in place as I was sliding in and out of the car. I removed it before reinstalling the sill plates.
Old Nov 8, 2024 | 12:25 PM
tkucala's Avatar
tkucala
Thanks for the responses. It looks like just a long the top edge is the way to go. I appreciate the help!
Old Nov 8, 2024 | 04:07 PM
Eliredandblack's Avatar
Eliredandblack
You really should leave a good bit of carpet underneath the sill plate. Having a few extra inches can Hurt. Remember that once you cut the carpet you can’t add it back. I left mine so it goes almost the width of the sill plate, never hurts to have extra carpet for Shrinkage or fitment issues.
Old Nov 8, 2024 | 05:22 PM
DonnieP73's Avatar
DonnieP73
Thiis is the ori:ginal carpet on the 73 before I replaced it:
Old Nov 8, 2024 | 05:46 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
It "can" hurt?
Old Nov 8, 2024 | 09:37 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
That's the way I remember and replaced my '72 carpet: about 1/2" to 1" from the sill plate screw holes.
Old Nov 8, 2024 | 10:00 PM
tkucala's Avatar
tkucala
Thanks again for all the responses. I was worried if I had too much carpet under the sill plate it could interfere with the door closing.
Old Nov 9, 2024 | 12:12 AM
4-vettes's Avatar
4-vettes
I'd be more concerned about the sill plate itself fitting properly.
Old Nov 9, 2024 | 01:34 PM
tkucala's Avatar
tkucala
I have had to do some trimming on the kick plate to fit the sill plate properly. I have NOS sill plates so I assume they are the proper size.
To Carpet under sill plate
