Missing Muncie ID letter
Just picked up a nice project...1968 L79 4 speed. When looking at the Muncie stamp, I don't see the A, B or C letter designstion to ID it as an M20, M21 or M22. Did the forget these often? I am guessing I need to look at the spline ro know for sure....any insight?
Looks like a 1968 Dec 15th stamp...
Steve
you have a muncie built nov 15th 1967 for the early 68 model year.
your spline rings on your input shaft will tell you the m20 or m 21 designation so yes you have to pull the tranny to find out.. or do some fancy math with your car speed/rpm/rear gear/ tire height calculation
Thought for you on cking for M20 or M21 and how I do it; put the transmission in 1st, jack it up and rotate the rear tire exactly 1 turn and see how many times and part of 1 turn the drive shaft turns at the trans. Ck the gear ratio for a M20 and M21 for 1st and you will be able to tell which one you have. M20 1st is 2.52:1 and M21 is 2.2:1. This is enough difference to be able to tell by rotating the tire exactly one turn. Hope this helps.
multiply your engine RPM to get number of tire rotations per minute, to get distance to get miles, to get time ( per minute) and then on to miles per hour use your phone to get speed.. ( don't trust your car's speedometer), convert inches to feet, to miles..
plug in the 2.52 and the 2.21 into the equation both. whichever agrees with your phone's speed ( or closest) is your 1st gear ratio. take your prevagen before you attempt this.
Now my brain hurts and i think it might be easier to pull the tranny and count the rings on the input shaft.
I see a VIN stamp on the trans. Is it original to the car? The standard setup for an L79 was M21/3.73 rear. Check was the code on the rear is would be another good clue
2 ways to do it
Easiest way for you is to get a friend to help. Youvare under the car while he runs around doing everything
- Take off your distibutor cap, mark where it is pointing.
- You climb under the car Wrap a piece of painters tape around your driveshaft so it overlaps.
- Cut the tape square and lay it on a smooth surface and mark a line 2-1/2 inches and mark it as m20 and a line 2-7/8 inches and mark it m21.
- With the tranny in nuetral, Have your buddy turn the rear wheel foward so you know which way the driveshaft will spin.
- Put the tranny in first gear
- Put the tape on so that as the driveshaft spins it will come to the m20 mark first, then the m21.
- Using a remote start switch have him use it and rotate the engine 1 revolution while watching the distributor rotor go one revolution.
- you watch the tape....when he stops at one revolution your are staring at your tranny first gear ratio. You should see m20 first then m21 if the tape is on correctly
- Put the cap back on, remove the remote start trigger, done...
Second way, you do it all yourself climbing under and out from under you car a bunch of times
If you have a 3.55 rear you will be slipping the clutch foooorrrrreeevvvveeerrr
Thanks group!!
Steve
Good question, I think you are correct. I must be thinking how to determine the rear ratio when the clutch is in neutral.
If the clutch is out and you are engaged in 1st gear, maybe I am thinking you would need to pull plugs, roll the Corvette rear tire on the ground exactly one turn and see how many turns the harmonic balancer rotates. The engine harmonic balancer would rotate more with a 2.52 M20 relative to 2.2 M21, right? This would be similar to Rescue Rogers distributor example where you are looking at engine rotation?
Dude seriously...you think that turning the rear tire, you would be able, with your normal human arms, be able to turn the differential, driveshaft, transmission in first gear, to count one full revolution of the motor, then do all the math backwards to figure it out....seriously. okay prove me wrong, without a calculator tell me how many fingers you have....
Sorry...had too. You are correct that from the engine side to the drive shaft side through the transmission you can figure out the rotational differenceof the 2 first gear ratios....thats what i did a while back.....you cant do it in reverse and stop at the driveshaft transmission interface.
If you had the transmission out you wouldnt need the drive shaft....just spin the input shaft and count rotations on the output shaft
Yes....this should have ended here but i couldnt stop myself after this
Nope...you blew it...you arent going to see the transmission turning anything on the other side if its in nuetral so you can turn everything unless.....noooo.....
U are right I was thinking rear ratio.
Now I think I could pull the plugs, put the trans in 1st and mark the location of the harmonic balancer, you come over and we push the Corvette on the ground one tire rotation and see how many times the harmonic balancer turns and back figure out what 4sp we have since the whole system is locked up at that point. Correct? When are you coming? LOL's!
OR, before we drop the trans, maybe remove the shifter arms, pull off the trans cover and count gear teeth.
Spark plugs in or spark plugs out....I am old ya know
Come over anyway and I will buy you a beer! My head hurts from thinking about this!
I know Tony and Arg0413 both and both are great people! Maybe you could help me knock out a couple of Corvette projects I have to complete. My better half told me if I die and leave her all this Corvette stuff, I am going to be in BIG trouble!
Seriously, if you pass through Louisiana, let me know. Cruising the Coast on the Miss Gulf Coast is a great excuse to come this way, 1st part of Oct every year, 9000+ vintage autos older than 1989 I think. Fun time! Lots of Corvettes there too.
Thank you very much for the invite and i will let you know if i ever get down that direction!!!!
