Vacuum lines from switch
Old Dec 18, 2024 | 01:43 PM
Wjones1000's Avatar
Wjones1000
3rd Gear
Default Vacuum lines from switch
I'm redoing the interior of my 80 vette and I have
This is the block running frim switch
a question. I found the 2 vacuum lines from the light switch one is black/blue and black/white and they run to a block that's hanging under my dash. I need to know where that plugs into. Its obviously supposed to be on something it also is marked with white on one side and blue on other. My power is fine as my lights come on but will not raise up. Please help?
Old Dec 20, 2024 | 06:12 PM
Wjones1000's Avatar
Wjones1000
3rd Gear
Well I found that it's the override switch for the headlights. I never got any response so I really don't know how to use this forum i guess.
Old Dec 20, 2024 | 06:59 PM
kanvasman's Avatar
kanvasman
glad you figured it out. I might suggest you get yourself a diagram of the vacuum sytem for your car. Especially if you still have vacuum operated headlights. It really will make figuring these things out much easier in the future.
Old Dec 20, 2024 | 07:10 PM
Bikespace's Avatar
Bikespace
This link might help.
https://www.corvette-101.com/vacuum.htm
Looks like your switch might be broken? It should look like what's in the link below (with a push/pull ****) and it screws into the small panel underneath the steering wheel.
https://www.zip-corvette.com/68-82-h...nder-dash.html
Old Dec 20, 2024 | 07:27 PM
Wjones1000's Avatar
Wjones1000
3rd Gear
Yes I believe it is. I have ordered me one so hopefully it will help on my lights. Thank you sir.
To Vacuum lines from switch
