A question about T-tops
Old Jan 24, 2025 | 03:18 AM
Z51JEFF's Avatar
Z51JEFF
Default A question about T-tops
What year T-tops are compatible for a 1981,if there are differences is it only with the bolt on hardware,are the actual fiberglass tops the same part from 68-82? Thanks for any info.
Old Jan 24, 2025 | 08:32 AM
kanvasman's Avatar
kanvasman
The 78 on up should match the 82. The bolt on hardware requires bolts to attach to the fiberglass shell. I am not sure if those bosses are there in the pre 78 shells or not. Dimension wise they probably are the same but everything else is different pre 78 models.
Old Jan 24, 2025 | 06:01 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I agree, your looking for 78 up tops. But they should be plentiful!
To A question about T-tops
