Door Glass Front Roller Hardware
There are some discrepancies between what the AIM shows, what the corvette vendors have on their web sites and the hardware that i have that I could use help sorting out. It looks like one of the POs changed some of the hardware so I’m not sure what i have is correct.
on one side, i have the roller, then a cupped washer with a rectangular slot and a white plastic bushing - that part looks right. On the other side, there were some zinc washers and a 7/16 nut with captured lock washer. It looks like I should have a rubber gasket like on the slide mounts and then ??? - the plastic washer and then the nut? Or do need a different nut?
Does the far left black metal washer have threads for the wheel?
