81 Power Antenna
Old Jan 30, 2025 | 03:14 PM
Donny1963's Avatar
Donny1963
5th Gear
Default 81 Power Antenna
Hello- Accidentally broke the power antenna mass on my 1981. How hard and what tools might be needed to get it out of the back of the car?
Old Jan 30, 2025 | 06:25 PM
av81's Avatar
av81
If you can get the muffler off it's pretty easy , I highly recommend using a band clamp on the drivers side muffler for ease of removal.
Old Jan 30, 2025 | 07:00 PM
stingr69's Avatar
stingr69
Let me know if you need a used replacement mast. I might have one.
Old Jan 30, 2025 | 08:38 PM
Prysmian46's Avatar
Prysmian46
Default 81 Antenna
You do not have to remove the muffler. I changed my a couple of times without removing the muffler. Just have patience and swear a little.
Old Jan 30, 2025 | 09:45 PM
interpon's Avatar
interpon
Pretty straight forward on my 79 to unbolt, (left muffler on ) ground off. The wiring was tricky for me.
https://www.corvetteforum.com/forums...na-wiring.html
Old Jan 30, 2025 | 11:46 PM
Bikespace's Avatar
Bikespace
I 3D printed a plug to replace that antenna. The car looks a lot less like a cartoon, now. I might have the STL file somewhere if you need it.
Old Jan 31, 2025 | 10:14 AM
Donny1963's Avatar
Donny1963
5th Gear
Really appreciate the tips and links. After taking a peak I have determined that the current unit is aftermarket. Now trying to decide if I want to spend the $200 to put in an OEM style. Or if any of you you have good luck with a cheaper Universal like what is in it now? I leaning towards replacing with an OEM type. Thoughts?
Old Jan 31, 2025 | 10:21 AM
Bikespace's Avatar
Bikespace
I'd look into a hideaway antenna (assuming you actually listen to the radio at all).
Not a recommendation, just the first one I found.
https://www.retromanufacturing.com/p...way-antenna-10
Old Jan 31, 2025 | 02:13 PM
Jon Hekking's Avatar
Jon Hekking
Do you have one for a factory CB radio car?
Old Jan 31, 2025 | 06:47 PM
Prysmian46's Avatar
Prysmian46
Default 81 antenna
Auto Pro makes a good replacement with a little modification.
Old Jan 31, 2025 | 11:19 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I got the whole thing......
FS (For Sale) FS late79-82 AM FM CB power antenna - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Feb 1, 2025 | 07:37 AM
stingr69's Avatar
stingr69
I only have one non-functional AM/FM/8 Track antenna for parts. It worked until I took it apart to replace the drive cable. Usually, i can reassemble and have no problems but this one gave me trouble. I already had a good spare.
Old Feb 2, 2025 | 01:09 PM
Reaper19's Avatar
Reaper19
I replaced mine on my 81 a few years ago with the model in the link below. It has a built in relay, so you can disconnect and bypass the antenna relay behind the passenger seat in the rear compartment. The model I purchased has a black mast, which I think looks better than the stainless steel color and matches the black trim around the back window. With the online discount code it comes out to only $58.39.
https://shop.advanceautoparts.com/p/...=power+antenna
To 81 Power Antenna
