73 with Z07 suspension
Old Feb 7, 2025 | 02:33 PM
vettestinger's Avatar
vettestinger
Acct Suspended 15 Feb 2025 by request
Default 73 with Z07 suspension
build sheet is on the fuel tank. what is the easiest way to get to the top of the fuel tank. I don't want to remove the build sheet only want the specs
Old Feb 7, 2025 | 05:09 PM
MelWff's Avatar
MelWff
Have you removed the rubber boot around the neck of the tank?
Old Feb 7, 2025 | 11:23 PM
Bikespace's Avatar
Bikespace
Flexible borescope?
If that doesn't work, it's easier to remove the fuel tank than it is to remove the body from the chassis, but either method will expose the top of the fuel tank.
Old Feb 8, 2025 | 07:04 AM
vettestinger
I have removed the boot and that's how I seen the build sheet . I think the difficulty will be in trying to drop the tank. everything on the car is original and I'm not sure I should be disturbing things.
Old Feb 8, 2025 | 07:05 AM
vettestinger
used that and could not get a clear picture of everything
thanks
To 73 with Z07 suspension
