Ignition switch on a '72
Old Apr 28, 2025 | 04:56 PM
kansas123's Avatar
kansas123
Default Ignition switch on a '72
Does anyone have a picture they can publish of the plug or plugs that plug into the ignition switch on a '72 model. I have been searching for it on the internet with no luck so far, thanks.
Old Apr 28, 2025 | 05:51 PM
randallsteel's Avatar
randallsteel
If no one chimes in with what you need, you could buy the wiring diagram from Doc Rebuilds, very accurate, color coded, has pictures of the plugs too.
Old May 1, 2025 | 03:50 PM
PJO's Avatar
PJO
Veteran: Marine Corps
https://www.corvetteforum.com/forums...-sequence.html
Old May 2, 2025 | 05:45 PM
kansas123's Avatar
kansas123
Thanks PJO, that helps a lot.
To Ignition switch on a '72
