Check matching numbers
Old May 4, 2025 | 07:55 PM
allaround56's Avatar
allaround56
Default Check matching numbers
Motor number VO413CTG
Vin 194670S409240
Old May 4, 2025 | 08:19 PM
MelWff's Avatar
MelWff
Vin 194670S409240
Is there a question you want answered? The CTG and the VIN indicates a 1970 350 CID, 300 HP, Automatic.
Old May 4, 2025 | 08:23 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
And on the motor next to the number you posted is the matching sequential number.
Old May 4, 2025 | 08:24 PM
Bikespace's Avatar
Bikespace
From a duplicate thread:
This is my Vin and my motor number. Can you tell me if they match or what is the motor number stand for?Motor number VO413CTG
Vin 194670S409240
Unfortunately, in 1970, the VIN did not indicate the specific engine that came with the car (other than it was a V8, like all C3s)
https://corvettec3.ca/vin.htm
Engine suffix code CTG is a base 300 hp 350 SBC that came with an automatic transmission.
https://corvettec3.ca/engines.htm
There should be a partial VIN stamp on the engine pad next to the code that you listed. The last 6 digits should match the last 6 digits of your VIN.
Old May 4, 2025 | 08:44 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Your serial number (09240) indicates it was completed May 15, 1970. (https://www.c3registry.com/index.php)
Your engine was assembled April 13th (0413).
They seem to go together fairly well - maybe a week or two wider than most early C3s, but I've never compared other Spring 1970 engine to car dates. Perhaps the '69 strike and new model year affected this sort of thing into 1970.
1972 was the first year engine codes were put into the VIN.
To Check matching numbers
