12 volt socket
Old Jun 10, 2025 | 07:11 AM
Shovel1's Avatar
Shovel1
Cruising
Default 12 volt socket
I have a 81 and I any putting it back together. I am not sure the 12 volt socket Cigarette lighter worked before and I tested it last night and it did not. So i installed a new one and it still does not work. I have power on the orange wire 12 volts with the battery installed but it's weird because with the battery only hooked up on the negative I have voltage on the negative side. What am I doing wrong. For the ground I an using the black wire with the ground conductor. Let me know Thanks for your time
