75' C3 Radiator
Old Jun 21, 2025 | 09:50 AM
Bfemrite01's Avatar
Bfemrite01
2nd Gear
Default 75' C3 Radiator
I am replacing the radiator in my C3 vette and I have ordered a radiator that doesn't fit because of the mounting brackets that were original, what is the easiest way to go about this? I was thinking either making new brackets or buying a factory radiator if I can find one.
Old Jun 21, 2025 | 10:32 AM
DWAVette's Avatar
DWAVette
You going back with electric fans or the original shroud and belt driven fan?
If converting to electric fans, I would take the effort and go with a quality aluminum radiator.
Old Jun 21, 2025 | 10:43 AM
Bfemrite01's Avatar
Bfemrite01
2nd Gear
I am sticking with the belt driven fan and shroud, I was have a new aluminum radiator but im thinking I need to go back to somesort of original.
Old Jun 21, 2025 | 03:37 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
There are an awful lot of aluminium radiators that fit. Or fit with minimal modifications.
You haven't stated which radiator you actually purchased.
As per a factory original? Not thinking that's possible.
As per a replacement that fits as per factory. A couple of options.
Let's start with, what did you actually buy? Why doesn't it fit? Photos could really help here.
To 75' C3 Radiator
