shifter will not go in reverse
https://assets.aaadirect.com/eyJidWN...ExMDU3MzIifQ==
https://www.chicagocorvette.net/diag...?d=2205&rc=144
My first question would be was this a running driving car before you rebuilt the transmission? If so did the shifter previously go into reverse without issue?
Did you rebuild the shifter, and if so does it have the correct reverse lock out rod in it? The 77-81 shifter is taller and uses a longer rod, if you got a 77-81 shifter rebuild kit or even just the 77-81 rod, it would be too long to allow the shifter too go into reverse.
The 77-81 shifter uses a different length spring too, though off the top of my head I don't know what the length's of the two springs are, or how much of a difference the length would make. I'd have to measure them to be sure of the length, I don't have their lengths noted in my system here. .
I'm working from memory here, but if I'm correct the proper assembly order is the bushings go inside the "T" handle, the rod and "T" handle go in the shifter, the reverse spring goes in the top of the "T" handle and the shifter ball screws on.
