convert to power locks
Old Aug 10, 2025 | 03:25 PM
Thomnewberg's Avatar
Thomnewberg
Cruising
Default convert to power locks
Suggestions for converting my manual lock on my 78 to power locks with keyless entry.
Old Aug 10, 2025 | 06:56 PM
kanvasman's Avatar
kanvasman
Look up A1 Electric. I believe the part was W01 TW. https://www.a1electric.com/Merchant2...uct_Code=W01TW I put them in my 78 and it was pretty simple. The hardest part was that the module can do so many different things it gets confusing, and the instructions are not very easy to explain. Basically they mount inside the door, linkage hooks up to the existing rod and you have to wire it up. Color coded wires, so it is easy. And it came with 2 key fobs. But it's an easy upgrade.
