THOUGHT it was a good idea....
Old Aug 12, 2025 | 01:22 PM
RightyTighty's Avatar
RightyTighty
Default THOUGHT it was a good idea....
I replaced the harmonic balancer due to a cracking rubber insulator ring. I figured while I was there, I'd put a nice shiny new timing tab on. Granted, I spent only $8 on a chrome timing tab, but its not a precision piece or equipment; a bent coat hanger would do the job. The timing mark on the replacement didn't match up with the original, so with the help of Lars' papers and a piston stop I made a 0 mark on the new balancer. I also stuck on MSD timing tape. The setup looked great and the car ran like before, as I just changed parts, I didn't touch timing. The other day I went to have a look at the all in timing, the wheels fell off the cart. The flash from the timing light bounced off the shiny new timing tab making it impossible to look at. On top of that, the timing tape is highly glossy, also reflecting the flash making it difficult to see the numbers. So between the chrome, the gloss and trying to keep the timing light away from moving parts, I'll be painting the chrome timing tab, removing the timing tape and sticking with my dial back timing light.
I love working on my car........LOL.
Old Aug 12, 2025 | 01:34 PM
litevette's Avatar
litevette
I intend to black out my hb with only white tik marks to see the degrees. What you’ve described sounds like it would look good, but I guess it’s a spot where function outweighs form or aesthetics. At least it’s running well for you! Thanks for sharing your experience so that others can learn. That Lars feller seems to know a thing or two about a thing or two!
Old Aug 12, 2025 | 01:36 PM
RightyTighty
Yes he does.
Old Aug 13, 2025 | 08:35 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Put a couple coats of Clear Satin on the shiny stuff...maybe that will take the glare away.
Old Aug 13, 2025 | 09:53 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
At least things worked out for you in the end....and Lars Rules!
Old Aug 14, 2025 | 09:32 AM
RightyTighty
doorgunner, thats a good idea......
And thank you for your service to our great country
Last edited by RightyTighty; Aug 14, 2025 at 11:58 AM. Reason: never miss an opportunity to thank a vet.
To THOUGHT it was a good idea....
